nuckollsr(at)cox.net Guest
Posted: Thu May 10, 2007 6:13 am Post subject: SPDT momentary push-button switch (comm flip-flop) |
At 09:34 PM 5/9/2007 -0500, you wrote:
| Quote: | I plan to install a comm flip-flop pushbutton switch in a wood grip from
Custom Aircraft Grips in Kelso, WA. I have a King KX 155 nav/comm which
requires a SPDT momentary switch for this feature vs. the SPST switch that
was supplied with the grip. The bore diameter in the grip for the switch
is 11/32 . I appreciate any leads that are provided regarding a source for
this switch. Thanks.
Are there actually three wires that are connected to
this switch? It's unusual to need more than a momentary
connection (usually ground) to a single flip-flop signal
lead. While there might be SPDT ON-(ON) switches described/
recommended for this application, I would be surprised that
a SPST OFF-(ON) switch would not be adequate to the task.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
wgill10(at)comcast.net Guest
Posted: Thu May 10, 2007 6:51 am Post subject: SPDT momentary push-button switch (comm flip-flop) |
Bob,
SPDT is correct per the installation manual (previously sent to you a
few months ago). If I had known earlier, I wouldn't have made this
provision when I ordered the grip.
I did touching the wire to ground and the frequency toggled ONCE. It was
necessary to then touch this wire to aircraft power to get it to toggle
a second time.
Bill
rjquillin(at)gmail.com Guest
Posted: Fri May 11, 2007 7:06 am Post subject: SPDT momentary push-button switch (comm flip-flop) |
At 22:09 5/10/2007, you wrote:
| Quote: | Aha! good data sir. How big are the resistors and to
what voltage do they pull up? The snipit from the
install manual suggests that pulling to ground is
the expected resting condition with the lead being
pulled up to +14 to effect a "flip".
I need to point out, my manual is for the 155A, not a 155 as Bill has.
My post was 'in case' the "A" had been inadvertently omitted from the model.
Bill also clearly states, if I read correctly, his IM details
connections to both +14 and ground; presumably in addition to the
input pin on the radio.
I'd like to see the IM page if possible...
For the 155A from the SM;
External input pin through 221 ohm resistor and diode in series to
the base of a PNP (with internal series base and emitter-base
resistors shown). Emitter hard +5, Collector pulled to ground via
47.5k and output to guts via 4.75k.
The input is protected by a 40V zener and debounce by a 330pF to
ground between the resistor and diode.
The 155A IM clearly shows N.O. momentary to ground to effect transfer.
Base pulled low, xstr turns on and supplies +5 via 4.75 to guts.
Bob, pdf to you directly to save BW.
Bill, let me know if you are interested too...
Ron Q.
