aadamson(at)highrf.com Guest
Posted: Fri May 11, 2007 4:29 pm Post subject: One to Many - Serial connections |
Someone must have come up with an elegant way to do this.
I've got some serial devices that I'd like to use to feed other devices. In
a couple of case, if the sending device will allow, I'd like to feed it to 3
downstream devices. These are single conductor with shield connections and
I've been racking my brain on how to take one to 3 (or 4, or N) and do them
the *correct* way, and via an eye pleasing way.
Anyone care to share how they'd do it?
Alan
Posted: Fri May 11, 2007 4:42 pm Post subject: One to Many - Serial connections |
I guess I should have said.... "Without using terminal blocks"... I'd prefer
to do it just with single conductor, shielded wire...
Alan
john(at)ballofshame.com Guest
Posted: Fri May 11, 2007 5:24 pm Post subject: One to Many - Serial connections |
You can terminate the source into a DB9. Use the one with solder cups
and solder all the pins together. The mating connector then has a wire
for each device you wish to hookup.
If it's a foil shield, 1/2 the DB9 can be signal pins, the other 1/2 can
be the shield from the source. If it's a braided shield with no wire
for the shield, you'll have to maintain the shielding through the
connector/backshell or something like that.
Just some random thoughts. There's probably a better way to do it,
-John
www.ballofshame.com
Alan K. Adamson wrote:
Alan
zk-vii(at)rvproject.gen.n Guest
Posted: Fri May 11, 2007 5:55 pm Post subject: One to Many - Serial connections |
Hi Alan,
Not sure if this is a 'correct' way, but we have taken multiple feeds and
solder spliced multiple lines and then used D pins for the connection. This
means easy to change / add other lines later if needed, where this gets too
bulky a DB9 has been used.
A second component that has worked well is we have a single DB25 (should
have been DB33) location which is like a mini approach hub for data lines.
All the avionics RS232 (plus a few others like PTT) lines come in and out of
this single DB male/female set. This includes unused GPS output feeds etc.
Any mods to what feeds what is normally just a pin change and doesn't
require burying into the avionics stack harnesses. Eg. I changed the
transponder FADC feed from the GNS to the GRT change rather than cutting
open the main harness.
Carl
ZK-VII - RV 7A QB - tying up bundles of wires.... - New Zealand
http://www.rvproject.gen.nz/
[quote] --
Posted: Fri May 11, 2007 6:27 pm Post subject: One to Many - Serial connections |
Holy smoke, you guys are brilliant... While not the perfect solutions, these
are some excellent ideas. What's even more ironic is that I was going to
use the DBX idea for grounds but hadn't even thought about the spoke/hub
idea for serial data.
Now I've got some thinking to do... I really like the "reuse or change idea"
and the idea of using DB connectors.... Hmmm, now to think thru how to make
a serial bus that doesn't take a bunch of space, and where a single
connector could be used for multiple buss paths...
Great ideas, please keep them coming....
Obviously there is a limit to this. If the RS232 chip that is/was used in
the Transmitting device can't "source" enough voltage, it may not be able to
drive unlimited numbers of downstream devices, but I can probably limit what
needs to be done to provide for my needs.
Thanks all!
Alan
