s_thatcher(at)bellsouth.n Guest
Posted: Thu May 17, 2007 5:46 am Post subject: Fuel Line Length |
Dave,
Great idea... I can't believe I never thought about doing it that way. The concept would also work for any other lines needed including control cables, brakes lines, etc..
Thanks again!
Scott
<<I am not building yet and cannot give you any dimensions. However, I have
done similar fuel line runs on a speed boat using steel braded lines. I went
to Home Depot and purchased a length of cheap clear hose the same diameter.
I ran the hose as needed and cut it to length. I removed the clear hose and
used it as a template, installing the steel braded connectors on the
workbench. ... Dave Thompson>>
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dbortol
Posted: Thu May 17, 2007 8:32 am Post subject: Fuel Line Length |
If you happen to be ordering something else from surpluscenter.com, like say a flap actuator, you can add on 100' of 5/32 clear tubing for $3.49. It's their item number 20-1022.
Dino
On 5/17/07, Scott Thatcher <s_thatcher(at)bellsouth.net (s_thatcher(at)bellsouth.net)> wrote:[quote] Dave,
Thanks again!
Scott
[quote][b] http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com [quote][b]
