japhillipsga(at)aol.com Guest
Posted: Thu Jan 05, 2006 10:14 am Post subject: First Flight |
Rick, your welcome to fly in my XL-3300 anytime you can get down here to Georgia. Bill N505WP
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Thu Jan 05, 2006 2:10 pm Post subject: First Flight |
Don't forget that Jim Pellen at Mid-Atlantic Sports Planes has a 601XL for
instruction or rental. It has a Rotax and a three-bladed prop, not a Jabiru:
http://www.maspl.com/
jim(at)pellien.com
-- Craig
NYTerminat(at)aol.com Guest
Posted: Thu Jan 05, 2006 10:20 pm Post subject: First Flight |
Jean-Paul
Thank you very much, there is alot of great info in Chris's article as well
as the other articles. It could not have come at a better time, I have a DAR
inspection on the 11th.
Bob Spudis
N701ZX CH-701
In a message dated 1/5/2006 9:04:52 AM Eastern Standard Time,
jean-paul.roy4(at)tlb.sympatico.ca writes:
<jean-paul.roy4(at)tlb.sympatico.ca>
Good day. Here is a link to an article written by Chris Heintz about the
first flight. Hope you find it interesting.
Jean-Paul
http://exp-aircraft.com/library/heintz/testing.html
jean-paul.roy4(at)tlb.sym Guest
Posted: Fri Jan 06, 2006 3:53 am Post subject: First Flight |
My pleasure Bob !
Jean-Paul
bkrisch(at)ouraynet.com Guest
Posted: Fri Jan 06, 2006 8:22 am Post subject: First Flight |
I feel obligated to reply to this question, hoping that my experience
might be of value to other builders. First of all, I was learning to
fly during the same period that I was building my 801, so when the
plane was finished I did not have a lot of piloting experience - and
virtually all of that was in a Cessna 172. During the high-speed taxi
tests everything was going so well that I was seduced into easing
back on the stick with the idea that I would lift off a foot or two
and then settle it back onto the runway.
Easy to do in a 172.
Big mistake in an 801!
When the 801 is ready to fly, the tail drops and the plane launches
into the air. What I had expected to be a foot or so off of the
runway quickly turned out to be more like 30 - and the sensations you
experience in that situation are not ones I can recommend -
especially to low-time pilots. The subsequent touch-down was not pretty.
The bottom line is flying your own creation is an incredible
experience - and I love my plane - but you have to know what to expect.
Bob Risch
johann(at)rafpostur.is Guest
Posted: Fri Jan 06, 2006 9:50 am Post subject: First Flight |
Hello all.
I would like to share my experience to the list, of my first flight of
the Zenith 701.
My total flying experience was 120 hours in a Kolb Firestar II, before I
did the first test flight in my Zenith 701, Joeing 701.
Those of you who know the Kolb aircraft would agree that this is a
perfect plane to exercise your landings, because you have a perfect view
from the cockpit with no obstructions in front. It is so easy to learn
the final touch of pitch and throttle control, because our light planes
can not be flared as a Cessna or other heavier planes because of light
weight and more drag on the Z 701
After a very thorough inspection of all controls, engine and
connections, and engine run, I did the test flight myself. No crow hops,
thank you.
I have a bad experience from when I did my first flight on a
Firestar.(Another story)
They are not for the unexperienced pilot. I could do them now, but not
then.
I took off to a safe altitude and moved the controls very cautiously for
the first minutes until I learned the feeling of the controls.
This plane is so responsive and is so easy to fly. No surprises and the
view is excellent. I know the view will be different from the 601 but I
am sure the controls will be similar.
As I mentioned before, the landing is without flare until you have
almost touched the runway with the throttle at idle in ground effect.
Just maintain a higher speed like Chris suggests in his article.
It is all about the fine pitch and throttle adjustment until you are
just a few feet from the runway at almost stall speed that you wait or
"flare" just slightly until you feel the smooth touch on the tarmac or
grass (which is more forgiving). A longer runway is great for this first
test flight. I say "flare" but it is almost like you just hold the stick
back if the nose tends to drop in your final touch attitude.
I know my experience is not much compared to most pilots on the list,
but I hope it give you some idea of how it is to test fly your new
plane, which is already a tested and approved design. There should not
be any surprises in the handling and performance of this design of Chris
Heintz, if you have completed everything according to plans.
Most important of all is, do you trust yourself to do it? Confidence is
very important here. If not, get someone to help you.
Happy flying.
Johann G.
Iceland.
Zenith 701
