jaybrinkmeyer(at)yahoo.co Guest
Posted: Mon May 21, 2007 6:42 am Post subject: Baggage door lock arm |
I hung my baggage door yesterday with some success... It's in pretty straight
and I was able to use the seamer to slightly bend the top and bottom edges to
match the fuse skins. However, the lock arm is too short to engage the catch
hole (it only sticks out about 1/2" from the door). Here's the lock (from
Aircraft Spruce) I'm using...
ACS DOOR AND BAGGAGE LOCK SETS
P/N 11-01600 $26.60
The door and baggage locks furnished with the ignition switches above are also
available separately. Set of two locks (one door and one baggage lock)
furnished with one key mated to both locks. The baggage lock may be used as
second door lock if preferred.
Has anyone else run into this issue? If so, how did you work around it? Is it
possible to purchase a longer lock arm? What source?
Jay
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
http://autos.yahoo.com/green_center/
Deems Davis
Posted: Mon May 21, 2007 6:54 am Post subject: Baggage door lock arm |
If I recall accurately, there is a substitute longer arm that come in
the kit.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Jay Brinkmeyer wrote:
| Quote: | Is it
Jay
scottmschmidt(at)yahoo.co Guest
Posted: Mon May 21, 2007 7:23 am Post subject: Baggage door lock arm |
The longer arm should have come with the kit.
Scott Schmidt
scottmschmidt(at)yahoo.com
Posted: Tue May 22, 2007 8:08 am Post subject: Baggage door lock arm |
Thanks! I'll go dig through my parts bins.
Jay
| Quote: | The longer arm should have come with the kit.
The fish are biting.
Get more visitors on your site using Yahoo! Search Marketing.
http://searchmarketing.yahoo.com/arp/sponsoredsearch_v2.php
