tdawson-townsend(at)auror Guest
Posted: Fri May 25, 2007 5:02 am Post subject: Traffic |
To go with your fancy panel, don't forget to get an active traffic
system, so you don't get whacked by somebody while you're both
heads-down looking at the pretty HITS displays.
Avidyne TAS system will display on Garmin, Avidyne, and Chelton
displays, amongst others.
Jeez, and I don't even work there anymore!
P.S. Your life will be easier if you consider this before you install a
headliner, since the top antenna needs a foil ground plane installed . .
Posted: Fri May 25, 2007 6:04 am Post subject: Traffic |
I understand that it would be nice having traffic in the panel, but isn’t that what ATC is there for? They can give you weather info, but not nearly as well as seeing it in color on your moving map, but is it distracting seeing all of the planes that are around you? I have talked to a number of pilots who don’t want to know about traffic. ATC will tell you about the ones that matter, but the others, well, don’t matter.
This may prompt a nice discussion about what traffic options are available and how helpful they are.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tdawson-townsend(at)aurora.aero
Sent: Friday, May 25, 2007 9:02 AM
Subject: Traffic
To go with your fancy panel, don’t forget to get an active traffic system, so you don’t get whacked by somebody while you’re both heads-down looking at the pretty HITS displays.
Avidyne TAS system will display on Garmin, Avidyne, and Chelton displays, amongst others.
Jeez, and I don’t even work there anymore!
P.S. Your life will be easier if you consider this before you install a headliner, since the top antenna needs a foil ground plane installed . . .
TDT
Tim Dawson-Townsend
Aurora Flight Sciences
tdt(at)aurora.aero
617-401-2522
[quote] [b]
Tim Olson
Posted: Fri May 25, 2007 6:39 am Post subject: Traffic |
Please don't take this personally Jesse, it's not meant that way.
That is one of the most laughable things I've heard for a while.
Truly amazingly laughable....especially in the days where the FAA
is contemplating user fees for services. You would be surprised
at how many planes there are cruising around underneath class B
airspace and how close the come to eachother...and often haven't
a clue. I have traffic on the PFD and MFD, which is about
as cool as it gets for display, but it's already been a potential
bacon saver a few times. Sure, the chance of an actual collission
isn't necessarily that great under the "big sky" theory, but
near misses can be pretty spooky as well.
The thing that TIS/TCAS and that sort of thing gives you is the
ability to give you a bearing, distance, altitude, and whether
or not the traffic is climbing or descending, so you know where
you need to be looking. Even with TIS, you sometimes have a hard
time picking out traffic at your altitude or slightly lower
because of visual ground clutter. In just that one respect that
you mention, TIS can add the distraction because if you see it
on the scope you may tend to get excited trying to spot it
visually....so it gives you a little adrenaline at times. But
saying that they'd rather not have it because of that would be like
saying you'd rather not have the MRI if you've been having
neurological issues, because it might tell you that you have
a brain tumor.
The most laughable part about the entire thing though was that
somehow ATC will tell you about the ones that matter. The problem
is, that's only true for IFR flight. Even on Flight Following
they don't always have time to provide those services. But,
I spend a ton of time on some flights where I'm VFR only, and
TIS is very valuable around the areas by me like MSP, MSN, ORD,
and so on. Had a callout last week where a chopper was heading
head-on towards me as I was on downwind and it called that one
out. Having it on screen was a nice tip off to look for it.
Whether you put it on the 496, 430, 530, 480, Chelton, or
whoever supports it, it's a pretty cheap option if you
go with a GTX-330. But as TDT mentioned, it would be
better yet with something more active than TIS. That said,
not only is it a shame that TIS may be life-limited, but I'm
sure glad I bought it because I have many many years to enjoy
it yet before it's gone...and it's already saved me. One of
the more memorable saves was in evening haze as I was nearing
Dunnellon, FL for fuel, BTW.
Jesse Saint wrote:
| Quote: | I understand that it would be nice having traffic in the panel, but
mritter509(at)msn.com Guest
Jesse,
I couldn't disagree more. Having traffic on the CMX 200 and 430 is a huge
help in the "see and avoid" environment of uncontrolled airports and VFR
local flights without flight following. The value of knowing which way to
look for traffic should not be underestimated - especially on hazy low
visibility days.
Mark
N410MR
| Quote: | From: "Jesse Saint" <jesse(at)saintaviation.com>
Subject: RE: Traffic
Date: Fri, 25 May 2007 10:02:57 -0400
I understand that it would be nice having traffic in the panel, but isn't
pilots who don't want to know about traffic. ATC will tell you about the
ones that matter, but the others, well, don't matter.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
_____
Subject: Traffic
To go with your fancy panel, don't forget to get an active traffic system,
so you don't get whacked by somebody while you're both heads-down looking
at
amongst others.
TDT
Tim Dawson-Townsend
tdt(at)aurora.aero
617-401-2522
Catch suspicious messages before you open them—with Windows Live Hotmail.
Jack.Phillips(at)cardinal Guest
Posted: Fri May 25, 2007 7:00 am Post subject: Traffic |
I agree with you Mark. I'll never forget the time I was on an IFR
flight plan (in VMC) and had a Bonanza whiz below me, on an almost
reciprocal heading about 100' below me. He was close enough I could
tell what color hair he had (actually, he was balding). No warning
whatever from ATC. I called and told Washington Center that a Bonanza
had narrowly missed me and the controller said "...uh, traffic no
factor." No fooling. He was already past me when I told ATC about him.
Don't rely on ATC to tell you about traffic. Just because they say
"radar contact" does not mean you are off the hook for looking for
traffic. Remember the old saying "If the pilot screws up, the pilot
dies. If ATC screws up, the pilot dies."
Jack Phillips
Planning to avoid building and put some time on the RV-4 this weekend
Posted: Fri May 25, 2007 7:01 am Post subject: Traffic |
Both responses so far are exactly what I was looking for. Thanks.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
rvbuilder(at)sausen.net Guest
Posted: Fri May 25, 2007 7:15 am Post subject: Traffic |
Jesse, I would suggest you acquire a better understanding on what exactly ATC is required to provide under different conditions and flight rules. Might I suggest a pilot’s license as a starting point. Bottom line is don’t EVER trust that ATC is 100% keeping you out of harm’s way. The PIC has ultimate responsibility for safety of flight, including rejecting vectors if ATC decides to drive you into another aircraft and your MARK1 eyeballs or onboard equipment tell you it’s a bad idea.
Michael Sausen
-10 #352 Limbo
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Friday, May 25, 2007 9:03 AM
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Subject: Traffic
TDT
Tim Dawson-Townsend
tdt(at)aurora.aero
617-401-2522
| Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com | y List utilities such as the Subscriptions page,[/b]http://www.matronics.bsp; - NEW MATRONICS WEB FO; http://forums.matronics.com</==================[/b] [b]
GRANSCOTT(at)aol.com Guest
Posted: Fri May 25, 2007 7:22 am Post subject: Traffic |
In a message dated 5/25/2007 10:06:39 AM Eastern Daylight Time,
jesse(at)saintaviation.com writes:
matter.
Jesse, as far as I know traffic is advisory only unless you are in positive
control zones...class A and Class B airspaces...all the other air space is just
advisory and not control...time permitting, only.
Patrick
************************************** See what's free at http://www.aol.com
Ray.R.Doerr(at)sprint.com Guest
Posted: Fri May 25, 2007 7:42 am Post subject: Traffic |
I love the TIS traffic on my 430 as well, but everyone just needs to remember it only works in the vicinity (approximately 50 nm radius) of some Class B and C airspace. As the FAA upgrades some of these ASR-9 radar sites to ASR-11, TIS will no longer be available. This upsets me greatly because in any other business you would not do an upgrade if you were going to loose an important feature like TIS.
Also you can never trust TIS for the whole picture in the sky because planes like Champs with no transponder (Mode A or C) will not show up on your TIS screen. This is why I like to fly at 10,500 or 11,500 in hopes that not many non transponder airplanes are flying at these heights.
Thank You
Ray Doerr
40250
N519RV
LloydDR(at)wernerco.com Guest
Posted: Fri May 25, 2007 7:46 am Post subject: Traffic |
ATC is not there for traffic avoidance for VFR pilots, only as work load
permits, or basically when they feel like it. Even when flying on an IFR
flight plan in VFR conditions, it is still primarily the PIC's
responsibility to visually scan and act on collision avoidance. In other
words ATC is there to help, but as PIC you are still ultimately
responsible. There has been many times that traffic could not be seen
until to late, think high wing versus low wing in the traffic pattern.
It is a reality, and especially for the North East coast people the
traffic corridor is highly congested and any tool that can aid in the
detection and avoidance of traffic would be a great add to the
situational awareness, I just wish I could afford the Avidyne solution
or others for that matter.
Dan
N289DT RV10E
_____
Sent: Friday, May 25, 2007 10:03 AM
isn't that what ATC is there for? They can give you weather info, but
to a number of pilots who don't want to know about traffic. ATC will
tell you about the ones that matter, but the others, well, don't matter.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
_____
Subject: Traffic
scottmschmidt(at)yahoo.co Guest
Posted: Fri May 25, 2007 8:15 am Post subject: Traffic |
Not much I can add. I am always too late on these responses. I need to plug my brain into this forum like others have.
Seriously, TIS is totally awesome, even around Salt Lake where I don't get alot of coverage. But you get coverage typically when you need it. It is so nice to come home from a trip and look down at the screen and before Salt Lake Approach even tells me anything, I can see how many planes are in the pattern at my home airport which is right next to Class B airspace. Because of the Garmin 330, lately I don't call approach because I can see all the planes as good as he can which was the only reason why I called in when I was getting close and half the time when I do call in they only give you traffic warnings when they are within 500 feet of yourself it seems. Of course the best way to go is to be IFR or talking to approach control or flight following while using the traffic system. I have both the 330 and the TrafficScope VRX system which I also like. I'd like to upgrade to the Zaon XRX. When my TIS isn't working I watch that close and when it tells me about traffic that is close I can normally find them. It all helps and is not distracting. One thing really nice about today's EFIS systems is the ability look out the window more. You would think you be looking inside more with all that equipment but on the ground you input your flight plan so that as you are flying you actually look outside more because you are not having to worry about airspace violations and you really don't have to monitor the engine because it will talk to you if anything gets in the yellow or red depending on how you have it set up.
Scott Schmidt
scottmschmidt(at)yahoo.com
rtitsworth
Posted: Fri May 25, 2007 8:40 am Post subject: Traffic |
I have an XRX interfaced to a 496 (paints graphical traffic on the 496 screen). The 496 accepts data from the XRX as if the XRX was a TIS GTX330 (same data/message format?). The XRX isn’t perfect (passive device), but It does identify traffic (direction, altitude, and inferred distance) and interface with the 496.
I’d be interested if anyone has experimented hooking the rs232 output from an XRX to a panel mounted MFD (in place of a GTX330) and if/how it works. It seems like it would be a poor man’s (passive) Ryan.
Rick
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Friday, May 25, 2007 12:15 PM
Subject: Re: RV10-List: Traffic
Scott Schmidt
----- Original Message ----
From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Sent: Friday, May 25, 2007 8:14:36 AM
Subject: RE: RV10-List: Traffic
Jesse, I would suggest you acquire a better understanding on what exactly ATC is required to provide under different conditions and flight rules. Might I suggest a pilot¢s license as a starting point. Bottom line is don¢t EVER trust that ATC is 100% keeping you out of harm¢s way. The PIC has ultimate responsibility for safety of flight, including rejecting vectors if ATC decides to drive you into another aircraft and your MARK1 eyeballs or onboard equipment tell you it¢s a bad idea.
Michael Sausen
-10 #352 Limbo
I understand that it would be nice having traffic in the panel, but isn¢t that what ATC is there for? They can give you weather info, but not nearly as well as seeing it in color on your moving map, but is it distracting seeing all of the planes that are around you? I have talked to a number of pilots who don¢t want to know about traffic. ATC will tell you about the ones that matter, but the others, well, don¢t matter.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Subject: RV10-List: Traffic
To go with your fancy panel, don¢t forget to get an active traffic system, so you don¢t get whacked by somebody while you¢re both heads-down looking at the pretty HITS displays.
Jeez, and I don¢t even work there anymore!
TDT
Tim Dawson-Townsend
tdt(at)aurora.aero
617-401-2522
y List utilities such as the Subscriptions page, | Quote: | | http://www.matronics.bsp; - NEW MATRONICS WEB FO; http://forums.matronics.com</ ================== " target=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-Li==== |
012345678901
sfdarton(at)yahoo.com Guest
Posted: Fri May 25, 2007 10:39 am Post subject: Traffic |
I am a retired SLC approach controller and currently
flying for a corporation. Do NOT count on traffic from
any controller anywhere whether you are IFR or
VFR!(IMHO) It is not required. Safety alerts are
required to be issued by controllers but the
parameters for what constitutes a safety alert are not
specified. Also the controller has to see the conflict
before traffic can be issued, controllers are human
and don't see or even understand every conflict.
As for TCAS or equivalent type displays, they are a
very valuable tool in the cockpit! you just need to
understand the limitations of you system.
Steve 40212
Food fight? Enjoy some healthy debate
in the Yahoo! Answers Food & Drink Q&A.
http://answers.yahoo.com/dir/?link=list&sid=396545367
poneill(at)irealms.com Guest
Posted: Fri May 25, 2007 10:59 pm Post subject: Traffic |
Has anyone had any experience with the passive Monroy or ProxAlert systems?
I've been looking at the passive systems as a possible supplement to 330 TIS
outside of TIS service areas. I think the price of the Avidyne's or L3's can
probably be better spent elsewhere.
I've seen good remarks on the Zaon XRX, but wanted to find a panel mounted
solution rather than portable. I really don't want to park a unit atop the
glareshield. With the RS232 output, the XRX would be the one to get if
there are panel mount options. They allude that someday they may offer such
a mounting option. From their web site:
"Options are or may soon be available for installing XRX into the panel with
significant reconfiguration of the hardware." ...Article Id: 30 - Version:
1 - Created: 05-12-2006:
http://www.zaonflight.com/component/option,com_kb/page,articles/articleid,30
/Itemid,1/
But a year later the only panel mount accessory they offer on their site is
for the MRX.
Any 3rd parties offering improved mounting options for the XRX?
Best Regards,
Patrick
rtitsworth
Posted: Sat May 26, 2007 5:00 am Post subject: Traffic |
Zaon had a panel mount prototype at their booth at SNF. Perhaps ready by OSH???
I’m building a Lancair ES (lurking here) and am currently planning on recessing the XRX into the top of the fiberglass glareshield, so it barely sticks up, but still has unobstructed visibility. The XRX display is disabled when it is in garmin comm (rs232) mode so there is nothing to see anyway.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill
Sent: Saturday, May 26, 2007 3:04 AM
I've been looking at the passive systems as a possible supplement to 330 TIS outside of TIS service areas. I think the price of the Avidyne's or L3's can probably be better spent elsewhere.
I've seen good remarks on the Zaon XRX, but wanted to find a panel mounted solution rather than portable. I really don't want to park a unit atop the glareshield. With the RS232 output, the XRX would be the one to get if there are panel mount options. They allude that someday they may offer such a mounting option. From their web site:
"Options are or may soon be available for installing XRX into the panel with significant reconfiguration of the hardware." ...Article Id: 30 - Version: 1 - Created: 05-12-2006:
http://www.zaonflight.com/component/option,com_kb/page,articles/articleid,30/Itemid,1/
But a year later the only panel mount accessory they offer on their site is for the MRX.
Best Regards,
Patrick
LarryRosen
Posted: Sat May 26, 2007 11:46 am Post subject: Re: Traffic |
The Zaon remote mount at S&F had a empty slot in the box fo an ADS B receiver. The install was very similar to the Avadyne with a transponder on top and bottom. It sure would be nice if it would be able to interface with my Chelton.
Larry
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
