Jekyll
Posted: Mon Jun 04, 2007 10:33 pm Post subject: Amp sensing with hall effect |
I started witring up my hall sensor tonight but thought I should get a peer review on my electrical monitoring concept before I go further. My particulars are:
RV-7A
Z-13/8 with fuse blocks
GRT EIS-4000
GRT Horizon 1 EFIS (single)
P-Mag, E-Mag
I wired up a single hall effect sensor with 3 wires going through it: M-bus feed from a FW mounted ANL; B-bus feed from the hot side of the battery contactor; SD-8 feed from the SD-8 relay to the B-bus. My architecture is based on the ability to read total bus amperage on 1 sensor in both primary and alternate operating modes. Operating in either mode will show the total amps: in primary mode the M-bus and B-bus will be totaled (of course the M-bus will include the E-bus through the diode); in alternate mode, the SD-8 feed will be added to the sensor on its way to the B-bus, thense to the E-bus. Battery charging can be determined by subtracting total bus amps from the alternator output to determine amps available to charge the battery. As I have both the SD-8 and a P-mag, I'm less concerned about knowing the exact in/out amperage condition of the battery than I am with knowing my actual bus amps when operating on the SD-8. I don't desire to add a second sensor or a switching capability.
The GRT system will show bus voltage with ample low voltage warning in all operating modes.
Just asking for comments to see if I missed anything before I commit the acts of cutting, stripping, crimping, soldering and drilling.
Jekyll
nuckollsr(at)cox.net Guest
Posted: Tue Jun 05, 2007 5:27 am Post subject: Amp sensing with hall effect |
particulars are:
RV-7A
GRT EIS-4000
P-Mag, E-Mag
SD-8. I don't desire to add a second sensor or a switching!
capability.
operating modes.
Jekyll
Sounds like you're anticipating the need for
knowing what currents are being draw for a variety
of flight configurations and making a determination
on-the-fly as to whether the alternator possesses
sufficient capability to accommodate the battery.
The BEST way to accomplish this is to do it in
advance. There are no flight configurations for
which power requirements can be deduced in advance.
This process is called a load analysis. The archives
are rich in conversation on this topic. Starting
on page 4 of:
http://www.aeroelectric.com/FAQ/AeroElectric-List/AeroElectric-List_FAQ.pdf
You'll find some filtered discussions on the
topic. You can do a paper analysis with the aid of a
form like
http://www.aeroelectric.com/articles/LoadAnalysis.pdf
There's a repository on the website for sample
load analysis conducted by members of this list in
Excel. See:
http://www.aeroelectric.com/PPS/Load_Analysis/
You can take one of these offerings as a starting
point for doing your own load analysis.
While the installation you propose is technically
correct, it also suggests that you're adding
instrumentation features to deduce what you should
already know, and have A, B, C and D plans for.
Making such real-time, in-flight measurements
gives you more work to do as a systems manager
and steals time and attention better expended
as a pilot.
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
Jekyll
Posted: Tue Jun 05, 2007 9:12 am Post subject: Re: Amp sensing with hall effect |
Thanks for the rapid reply. I've done a complete load analysis and update it whenever I make any changes.
Jekyll
rvreynolds(at)macs.net Guest
Posted: Sat Jun 16, 2007 4:03 am Post subject: Amp sensing with hall effect |
I ran the M-Bus, E-Bus and feed from the Battery contactor thru the
hall sensor. I want to read amps being used. I don't care about amps
to the battery being charged. If the bus voltage is above 13,5, the
battery is charging.
Be sure to run the wires thru the hall sensor in the same "sense", ie
+ to -, or else you will subtract one of the amp values.
Richard Reynolds
RV-7A
GRT EIS-4000
P-Mag, E-Mag
the SD-8. I don't desire to add a second sensor or a switching!
capability.
drilling.
Jekyll
http://forums.matronics.com/viewtopic.php?p=116592#116592
Jekyll
Posted: Sat Jun 16, 2007 1:18 pm Post subject: Re: Amp sensing with hall effect |
Thanks Richard. I did the same. Yes, I have all the trons shepparded in the same direction.
Jekyll
