tc1917(at)hughes.net Guest
Posted: Mon Jun 11, 2007 2:32 am Post subject: prop |
Just want to say that when I folded my firestar with a single blade, I
always go verticle with it but I take a large piece of foam with a cut in
the center and slide it on the down prop blade. It sits on the boom and the
wings cradle it on both sides. very stable to trailer. I also do the same
thing with my sling shot, three blade warp or ivo. pad the down blade with
a large piece of foam. You have to pad or tie your blad when it is in the
horizontal if you intend on trailering. Otherwise it woulds smake your ail.
tubes. just wanted to add my two cents. Ted Cowan, Alabama. p.s. If I
was trailering for a long distance, as you would buying or selling your
plane, get yourself an industrial roll of clear wrap and litterly mummify
your plane. it will get there safe without vibration and mostly dry if you
do it right. easy to cut off. it will also keep your wing from falling off
the wing holders.
