DAVELEIKAM(at)wi.rr.com Guest
Posted: Fri Jun 15, 2007 7:40 pm Post subject: tank fitting sealer |
What is everyone using to seal the threads of the fittings in the fuel tanks? Pro-seal? When sealing up the senders, do you smear the stuff on the gasket surfaces as well as the screws and flanges?
Dave Leikam
40496
Mike Whisky
Posted: Sat Jun 16, 2007 1:41 am Post subject: Re: tank fitting sealer |
DAve,
I used Proseal for the fuel sender but not on the screws. I did presure test it and it works fine.
I still have a tiny leak somewhere but not at the fuel senders.
Michael
www.wellenzohn.net
_________________ RV-10 builder (flying)
#511 |
flysrv10(at)gmail.com Guest
Posted: Sat Jun 16, 2007 2:37 am Post subject: tank fitting sealer |
I used proseal for the threads as well as the sender. I discarded the gaskets.
do not archive.
On Jun 16, 2007, at 12:39 AM, Dave Leikam wrote:
| Quote: | What is everyone using to seal the threads of the fittings in the fuel tanks? Pro-seal? When sealing up the senders, do you smear the stuff on the gasket surfaces as well as the screws and flanges?
Dave Leikam
40496
