Flange Tweaking Tool
sky_ranger161
PostPosted: Wed Jun 13, 2007 7:36 am    Post subject: Flange Tweaking Tool Reply with quote
This is nothing earth-shattering, but I thought I'd share my flange tweaking tool that I came up with. I'm sure there are a lot of other versions out there, but I thought this was pretty clever, so here you go.
It's two 3/4" thick pieces of plywood with the front edges rounded to a 1/8" radius. Sandwiched between the plywood is a piece of .032 aluminum scrap. I used .032 because I happen to be tweaking .025 flanges. You can adjust the distance between the plywood by placing different thickness shims between the "handles" to hand-tweak different flanges and bends all over your project. You can even make a second set with a different bend radius routed on the front if called for.
It's not readily visible in the overall picture, but the aluminum shim is about 20mm shorter than the wood pieces - giving you the place to insert the flange you're tweaking. This thing works like a charm tweaking the wing ribs that I'm working on now. The size of this one is 150mm long x 30mm wide.
Tweak on my brothers.
Debo Cox
XL/Corvair Scratchbuilder
Nags Head, NC
Choose the right car based on your needs. Check out [url=http://us.rd.yahoo.com/evt=48518/*http://autos.yahoo.com/carfinder/;_ylc=X3oDMTE3NWsyMDd2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDY2FyLWZpbmRlcg-- ]Yahoo! Autos new Car Finder tool.[/url]
 Filesize:  41.95 KB
 Viewed:  340 Time(s)
 Filesize:  40.87 KB
 Viewed:  342 Time(s)
 Filesize:  39.27 KB
 Viewed:  336 Time(s)
TxDave
PostPosted: Wed Jun 13, 2007 11:53 pm    Post subject: Re: Flange Tweaking Tool Reply with quote
Another cool tool, Debo. I checked out those great looking wing ribs on your website. The flange tweaker must work well.
Dave Clay
Temple, TX
