CH640: Findings at 2nd condition inspection
steveadams
PostPosted: Thu Jul 19, 2007 10:06 am    Post subject: CH640: Findings at 2nd condition inspection Reply with quote
I just completed the second condition inspection on my CH640. I have 450 hours on the tach. Everything looked good except for a few items requiring attention. If anyone is interested, here is what I found.
1. New brake pads. I probably could have gone another 6 months, but figured I might as well change them now. This was the first set of pads. The original tires are still fine.
2. There are 2 panels on the aft side fuselage which cover the elevator trim mechanism. On the ground there is good clearance between these panels and an underlying bracket that attaches the trim tabs to the trim tab bellcrank. However, in flight they must be bowing in enough to rub on the bracket and have etched a groove on one side of the bracket. I am going to put in a new bracket and put a 1/8" piece of teflon on the bracket to prevent wear in the future.
3. The front spinner bulkhead had a crack extending from one of the screw holes inward and 1/3 of the way around the bulkhead. I had noticed the last few flights that at some rpm's there was a bit more vibration than I am used to. I am going to replace the bulkhead. Interestingly, I took a flight this morning without the spinner to see how much difference it made. To my surprise I couldn't detect a difference in speed with a quick run at 4500 feet, and CHT's were a bit lower. Even though it looks ugly, I may just fly without a spinner for a while.
4. The throttle cable was not pushing the throttle all the way to the stop at full power. It was a very small gap, but every little bit of power helps. I just adjusted the linkage.
That's it. Now I can get back to flying.
cj.tremblay(at)videotron.
PostPosted: Fri Jul 20, 2007 9:46 am    Post subject: CH640: Findings at 2nd condition inspection Reply with quote
Hi Steve,
Thanks a lot for taking time to do a status on your 450 hours inspection. I
find it positive, I think it is very low number of problems, it's sound
good. Can I ask you to provide us a photo on point 2 about clearance of
panels. I want to verify if this need a plan modification to guaranty
clearance, and eventually I want to document this adjustment it in my web
site.
Thanks again
Christian Tremblay
A guy who build a CH640 aircraft from plan
http://www.zodiac640.com/
-----Message d'origine-----
De : owner-zenith-list-server(at)matronics.com
[mailto:owner-zenith-list-server(at)matronics.com] De la part de steveadams
Envoyé : Thursday, July 19, 2007 2:07 PM
À : zenith-list(at)matronics.com
Objet : CH640: Findings at 2nd condition inspection
http://forums.matronics.com/viewtopic.php?p=124799#124799
