ventura(at)brandeis.edu Guest
Posted: Thu Jun 21, 2007 9:55 am Post subject: LongEz Limitations |
Weav, since you have so much experience with LongEz's, I was hoping you
would give me a little advice. I have a 118 HP O-235 L2A powered LongEz
which I bought from a friend's estate. It is a heavy aircraft with an
empty wt of 960lbs. I have never flown this airplane, but eventually
hope to make some very long flights with it, including a trip up to
Alaska. (I am presently making some repairs and minor modifications to
the airplane.)
But with me and full fuel my takeoff wt would be 1472 lb, well above
the designed gross wt of the airplane, and I have not even added any
baggage yet. I have seen LongEzs placarded with gross wts of 1600lb,
and when I asked the builders about that they said they set that as the
gross wt of the airplane so they would never be bothered by the FAA.
So my question is what kind of maximum takeoff wt would you consider
safe in this kind of LongEz on a standard day, and what kind of runway
length would I require? What is the minimum runway length you feel
comfortable with when flying at 1325lbs?
If anyone else has any experience in this area, I would like to hear
your comments as well.
Thanks for your help.
Joel Ventura
Andover, MA
| | - The Matronics EZ-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?EZ-List |
Mytyweav(at)earthlink.net Guest
Posted: Thu Jun 21, 2007 10:52 am Post subject: LongEz Limitations |
Joel.... The Long EZ has evolved quite a bit over the years from the
simple "lightweight" Long that Burt loved so much. Without going into
the archives to locate all the weights that these airplanes have been
flown at, I'd just like to say that Dick Rutan and Mike Melville both
changed to 0-360's and lots of extra fuel etc etc and still carried
baggage. They tried never to "land" with all that weight but even that
was sorta tested a time or two as I recall. The difference between an
0-235 and an 0-320 is enormous in the Long. The 0-320 should have been
the engine of choice right in the beginning. (just my opinion after
flying them both quite a bit.) You can still load it up with all your
stuff and plenty of gas and fly quite fast AND comfortable for hours.
The POH for the Long specifies the max landing weight and that's what
I'd continue to try and do. You can take off a lot heavier and fly just
fine as long as you obey the CG limitations. Just don't land it heavy
unless you can very smoothly "roll it on"... Working on the gear leg
attachments after the plane has been built and flown is not really a fun
chore.
I'm sure there are other email lists that the Canard guys are on and I'd
recommend you post to them and get their opinions too. The Long EZ is a
very strong and capable airplane. Put a Lycoming 0-320 with 160 hp on
the back and go enjoy what the plane can really do.
Good Luck,
Fred Weaver
Joel Ventura wrote:
you would give me a little advice. I have a 118 HP O-235 L2A powered
LongEz which I bought from a friend's estate. It is a heavy aircraft
with an empty wt of 960lbs. I have never flown this airplane, but
eventually hope to make some very long flights with it, including a
trip up to Alaska. (I am presently making some repairs and minor
modifications to the airplane.)
the gross wt of the airplane so they would never be bothered by the FAA.
Joel Ventura
Andover, MA
