joe(at)kfiz.com Guest
Posted: Tue Jul 10, 2007 7:12 am Post subject: Canopy Problem |
Guys,
I have a big problem! My canopy developed a crack and spread too far before
I could drill a stop hole. It looks like I will have to buy another canopy.
Before I call Zenith, I thought I would seek advise about where I can get
the best deal on one of these. I have another builder coming over this
afternoon to look ovr the situation! Any advise?
Joe in Oshkosh
601zv(at)ritternet.com Guest
Posted: Tue Jul 10, 2007 7:49 am Post subject: Canopy Problem |
I have the same problem, cracked it before getting around to starting
installation. Obviously they are far more fragile than I suspected. I left
mine rolled for a long time and then unrolled it to avoid it taking a "set".
This was a mistake, because it is far more flexible than I would have
thought and does not seem to take a set at all. Anyway, on the advise of
others previously, I'm currently planning to order one from TODD'S.
http://www.toddscanopies.com/
carlossa52(at)gmail.com Guest
Posted: Tue Jul 10, 2007 7:54 am Post subject: Canopy Problem |
Todd's canopies has been mentioned by a number of people...
Carlos
CH601-HD, plans
On 10/07/07, Joe <joe(at)kfiz.com (joe(at)kfiz.com)> wrote:[quote] --> Zenith-List message posted by: "Joe" <joe(at)kfiz.com (joe(at)kfiz.com)>
Guys,
Joe in Oshkosh [b]
dredmoody(at)cox.net Guest
Posted: Tue Jul 10, 2007 8:20 am Post subject: Canopy Problem |
No advice here, just a related question. Since I experienced a few small, short cracks that I had to stop drill and backfill, I am doubtful of how long my plexiglass canopy will go before I have to replace it. Does Todd's Canopies offer a Lexan canopy for the 601XL? Lexan is a lot easier to work with in my limited experience and is much more resistant to cracking and scratching. If Zenith had offered it as an option, I would have gone that route from the beginning.
Dred
Posted: Tue Jul 10, 2007 9:11 am Post subject: Canopy Problem |
I just talked to Todd. He said his conopies are much thicker and stronger. 60XL canopy is $340 + freight (estimated to Arkansas at $140), and weighs about 2-1/2 pounds more than the ZAC canopy. He can make one and have it on the way in a couple of days. Anyone know the current ZAC canopy price?
Posted: Tue Jul 10, 2007 9:41 am Post subject: Canopy Problem |
Hi Ed,
I agree with you that Lexan (polycarbonate) plastic would be easier
to form into a canopy than Plexiglas (acrylic). Unfortunately, Lexan
scratches very easily. For use in optical situations like this, it
is common practice to "Hard Coat" polycarbonate with
polyurethane. This is a process I have not found available for small
runs like our canopies. Without it, the canopy would quickly become
unusable since you won't be able to see through all the scratches.
Paul
XL fuselage
At 09:19 AM 7/10/2007, you wrote:
| Quote: | No advice here, just a related question. Since I experienced a few
Dred
Afterfxllc(at)aol.com Guest
Posted: Tue Jul 10, 2007 9:42 am Post subject: Canopy Problem |
When mine FELL from the straps dry rotting I replaced it and zeniths price was 600 and change.... OUCH!!!
Jeff
See what's free at AOL.com.
ccwacker(at)HOTMAIL.COM Guest
Posted: Tue Jul 10, 2007 9:47 am Post subject: Canopy Problem |
I just bought one from Zenith, $525.00 plus shipping.
Chuck Wacker
601XL Quick Build
[quote]From: "Robin Bellach" <601zv(at)ritternet.com>
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: Re: Canopy Problem
Date: Tue, 10 Jul 2007 12:06:31 -0500
Posted: Tue Jul 10, 2007 10:40 am Post subject: Canopy Problem |
Hi Joe,
The cracked canopy may be used as a template for trimming and spotting
holes and edges could it not?
Might for this reason be best to use a canopy from Zenith again. You'd
probably want to ask what grade of acrylic
plastic they're using as well or if they've gone to a more durable
material recently. Plastics keep changing and you
may have the opportunity to improve the available product. Cost would
be the lesser of concerns at this point I think.
During the process,
Remember to use small diameter hose segments around the screws when they
go thru the plastic and manually break
all hole edges both sides with a relatively new countersink. Don't
over-tighten, etc. Study the crack to determine what
caused it before starting over. Hope you have better luck next round.
I remember sweating bullets when I did mine.
Good luck,
Larry McFarland - 601HDS at www.macsmachine.com
Joe wrote:
Guys,
before I could drill a stop hole. It looks like I will have to buy
another canopy. Before I call Zenith, I thought I would seek advise
about where I can get the best deal on one of these. I have another
builder coming over this afternoon to look ovr the situation! Any advise?
Joe in Oshkosh
Posted: Tue Jul 10, 2007 12:08 pm Post subject: Canopy Problem |
When I built my ultralight, the kit came with a sheet of Lexan which I bent over the frame and trimmed to fit. That windshield is still in very decent condition despite residing in a dusty hanagr infested with birds which build nests 24/7 all summer long.
The few scratches that have happened over the last four years have been where my gps and the corners of the panel rub on the inside surface. I think they might be remedied with the micro mesh technique but since they aren't in the critical field of view, I haven't bothered. I don't think my sheet of Lexan had any special treatment so maybe it would be such a bad deal after all.
Ed
---- Paul Mulwitz <p.mulwitz(at)worldnet.att.net> wrote:
Hi Ed,
Paul
XL fuselage
planecrazydld(at)yahoo.co Guest
Posted: Wed Jul 11, 2007 2:16 am Post subject: Canopy Problem |
..since these are thin wall free blown bubbles, it is unlikely that it would nest well. perhaps cutting all of it away except for the peripheral 6" band would allow it to be a template of reasonable accuracy?
LarryMcFarland <larry(at)macsmachine.com> wrote:[quote] --> Zenith-List message posted by: LarryMcFarland
Hi Joe,
During the process,
Good luck,
Guys,
Joe in Luggage? GPS? Comic books?
Check out fitting [url=http://us.rd.yahoo.com/evt=48249/*http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz] gifts for grads[/url] at Yahoo! Search.
