Closing baggage floors & rear seats floors
jwt(at)roadmapscoaching.c
PostPosted: Wed Jul 11, 2007 3:03 pm    Post subject: Closing baggage floors & rear seats floors Reply with quote
Michael,
You listed everything that I have under the floors (but I haven't flown yet
and could still fall out of the sky - only joking). I ran my strobe wiring
down different channels from the other wiring.
The conduit was really a blessing for the things I needed to add - ELT
remote cable, baggage lights power, etc.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Paint prep and LOTS of misc stuff
indigoonlatigo(at)msn.com
PostPosted: Wed Jul 11, 2007 3:18 pm    Post subject: Closing baggage floors & rear seats floors Reply with quote
Remote ELT cable for the switch
Power lines to activate Strobe from switch in panel
Power line(s) to the solenoid(s)
Hopefully I have everything else in my plane but have forgotten for the
moment.
John G.
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Subject: Closing baggage floors & rear seats floors
Date: Wed, 11 Jul 2007 14:54:19 -0700
Hello,
I am just about to close the baggage floors and just want to check if I
really really am prepared to route everything through the underfloors that
is necessary.
Thats what I have:
2 standard Vans conduits left & right (from tailcone to side panels
fuselage)
they will route
- plus battery cable
- tail light
- strobe l & r
- COM antenna and probably also transponder antenna cable
Static line
Since I am not sure about my avionics I might need to route also the AHRS
cable through it. Will that work?
Feedback welcome.
Michael
RV-10 builder (wings)
#511
http://forums.matronics.com/viewtopic.php?p=123302#123302
billderou(at)yahoo.com
PostPosted: Wed Jul 11, 2007 6:21 pm    Post subject: Closing baggage floors & rear seats floors Reply with quote
My RV-10 has been flying since last August. Since then I have relocated the GPS antenna, added a backup electrical bus, changed out the ELT, and changed out the solid state gyro.
Now the two tubes I provided are stuffed full. Looking back I should have added one tube on each side just to handle the unknowns. If they remain empty ... so be it.
Bill DeRouchey
N939SB, flying
Michael Wellenzohn <rv-10(at)wellenzohn.net> wrote:
[quote]--> RV10-List message posted by: "Michael Wellenzohn"
Hello,
I am just about to close the baggage floors and just want to check if I really really am prepared to route everything through the underfloors that is necessary.
Thats what I have:
2 standard Vans conduits left & right [quote][b]
Mike Whisky
PostPosted: Fri Jul 13, 2007 9:25 am    Post subject: Re: Closing baggage floors & rear seats floors Reply with quote
Thanks for the feedback. I did route a third conduit now. so whatever happens I´ll be able to pull new wires through.
Michael
www.wellenzohn.net
RV-10 builder (flying)
#511
