		alfolavf(at)online.no Guest
				 Posted: Sun Feb 12, 2006 6:15 am    Post subject: PVC-tube in the wings? |
				Hi builders!
 Thanks for the inputs on the flap hinge! I'll go for the split-pin metod then!
 Another one:
 I'm thinking towards intstalling wires in the wings also, and saw a builder on the net who'd installed a small PVC-tube in the wings.
 It made room for several wires (landing light, posn light, antenna etc)
 Anyone else have done this?
 It seems to me like a good idea??
 Specially if I also put a light line in there so I can replace or add thing later.
 Thoughts anyone??
 Best regards Alf Olav Frog / Norway
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		mtaylo17(at)msn.com Guest
				 Posted: Sun Feb 12, 2006 6:35 am    Post subject: PVC-tube in the wings? |
				Hi Alf,
 I did this on mine. I used lawn irrigatoin tubing, which is very light, is
 thin walled and should last a long time. It was cheap too. The other thing
 to look out for is that the OD matches a hole cutter size you have. The
 irrigation tubing was exactly 3/4" OD. I'm not sure how that will work out
 for you in Norway though, everything being metric there, and I'm not so sure
 about the availability of such tubing there either. Here, it's readily
 available at any hardware store. See it at www.4sierratango.com/wings2.htm
 Mark
 RV-7 Finishing & Firewall FWD.
  	  | Quote: | 	 		  From: Alf Olav Frog <alfolavf(at)online.no>
 Reply-To: rv7-list(at)matronics.com
 To: <rv7-list(at)matronics.com>
 Subject: PVC-tube in the wings?
 Date: Sun, 12 Feb 2006 15:06:14 +0100 (CET)
 Hi builders!
 then!
 Another one:
 later.
 Thoughts anyone??
