rudderdancer
Joined: 28 Aug 2006 Posts: 27 Location: Victorville, CA
msm_9949(at)yahoo.com Guest
Posted: Wed Aug 29, 2007 7:20 pm Post subject: Primer Fuel Lines / Model II |
I'd start with replacing the cracked primer line. It does get brittle with age and exposure to fuel.
rudderdancer <jhenryhall(at)mac.com> wrote: [quote]--> Kitfox-List message posted by: "rudderdancer"
I have a Model II here in the High Desert of California. It's been on the hot side lately and I discovered fuel dripping from the plane. It was coming from a cracked line connected to the plastic "T" fitting of the primer. Old age and possibly a build up of temperature caused pressure in the fuel system?
What would be the best corrective action? I not sure I like such a fragile looking primer arrangement.
Thanks. [Question]
Read this topic online [quote][b]
john(at)leptron.com Guest
Posted: Wed Aug 29, 2007 7:23 pm Post subject: Primer Fuel Lines / Model II |
I installed a standard (short stroke) primer on my fox. I now have removed
my choke, it is not needed any more.
I ran the 1/16 inch copper tubes, to the carbs the same, it works great.
John Oakley
rudderdancer
Posted: Thu Aug 30, 2007 6:55 pm Post subject: Re: Primer Fuel Lines / Model II |
Thanks for the answers, and for John's idea of the short stroke primer, I'll check with Aircraft Spruce.
