mattreeves(at)yahoo.com Guest
Posted: Sun Aug 26, 2007 3:51 pm Post subject: How to check and alternator?? |
I have a 35 amp alternator and a 12 volt concorde battery and a Linear Voltage Regulator. Lycoming 160hp
I have noticed the voltage reads just under 14 volts with the engine running.
I also noticed the ammeter stays at zero unless I turn on something such as the nav lights or strobe lights. Then it goes to the negative about 1/16 of an inch on a +40/-40 amp guage. This remains the same even at high throttle settings. No change at low or high power settings.
I have a shunt. I checked all the wiring an it is correct from Bingelis' book so I am wondering if my alternator is bad.
What is the best way to check an alternator on an airplane? Can't really take it to my neighborhood Advance AutoParts. They might wonder what the big fan is for.
Thanks!!
nuckollsr(at)cox.net Guest
Posted: Sun Aug 26, 2007 5:31 pm Post subject: How to check and alternator?? |
At 04:51 PM 8/26/2007 -0700, you wrote:
| Quote: | I have a 35 amp alternator and a 12 volt concorde battery and a Linear
big fan is for.
Sounds like your alterantor is working. You can't have a bus votlage
greater than about 12.8 if the alternator is not picking up ship's loads.
Where is your ammeter in the system? If you have a -0+ reading ammeter,
then it suggests a battery ammeter which is almost useless as a
diagnostic tool.
Suggest that you convert the ammeter to a +only alternator load
meter. Then you'll see the alternator functioning as expected . . .
picking up loads as they are added to the system.
frank.hinde(at)hp.com Guest
Posted: Mon Aug 27, 2007 6:30 am Post subject: How to check and alternator?? |
It depends on where your ammeter is connected as to what info it is giving you. The best way to know if your alternator is working adequately (i.e is making more current than is consumed by the electrical devices in your airplane) is to watch the voltmeter.
I.e if you turn everything on and it maintains above say 13.5V it working just fine.
If it drops below 12.5V then it is either malfunctioning or is undersized for the application.
Sounds to me like your unit is working just fine.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Reeves
Sent: Sunday, August 26, 2007 4:51 PM
Subject: How to check and alternator??
Thanks!!
Posted: Mon Aug 27, 2007 8:34 pm Post subject: How to check and alternator?? |
Thanks for messages.
Here's the answer to your questions.
I have a Chief Aircraft +/- 40 ammeter with a 40amp shunt.
I think my alternator is 35 amps but can't remember - I'll have to look that up. I am running Nav lights, strobe lights, wig wag lights, and a full Garmin stack so I'm thinking I may need to upgrade my alternator. Will have to add that up before first flight to see the load.
The ammeter has a positive and negative terminal on the back. The positive is connected to to the small screw on the shunt which also has a large screw on the same side which is wired directly to the main power bus which also splits to a wire between the master and starter relay. The negative side on the back of the ammeter is connected to the opposite small screw on the shunt which also has a large screw which is wired through a 60amp circuit breaker to the main power bus.
Kinda hard to explain without a picture. I followed the Bingeles book when I wired it up a few years back so maybe I messed something up.
I do know that the volt meter reads barely under 14 volts with the engine running.
Thanks for the help!!!!
Matt
P.S. My brother Danny has an RV-7A completely built in the basement of his house in Harrisburg, PA. His MIL lives in the garage. We got an estimate of $7000 to have someone dig a hole, cut the blocks out and put it all back together. We are hoping for some suggestions as to how to get it out. (The airplane - not the Mother-In-Law)
"Robert L. Nuckolls, III" <nuckollsr(at)cox.net> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
[quote]I have a 35 amp alternator and a 12 volt concorde battery and a Linear
take it to my Choose the right car based on your needs. [quote][b]
raymondj(at)frontiernet.n Guest
Posted: Mon Aug 27, 2007 9:36 pm Post subject: How to check and alternator?? |
Matt,
The only alternative I can think of besides taking it appart is to bring it up through the floor and out a picture window. Might be cheaper than all that digging and masonry work. Even cheaper if you're a carpenter.
Best of luck,
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
Posted: Fri Aug 31, 2007 12:22 pm Post subject: How to check and alternator?? |
At 09:24 PM 8/27/2007 -0700, you wrote:
| Quote: | Thanks for messages.
running.
The -zero+ reading ammeter is a BATTERY ammeter. When things
are running normally (alternator carrying ship's loads and
battery fully charged) then it SHOULD read at or near zero.
Turn some things on with the engine not running. Let them run
of the battery for 10 minutes or so. The ammeter should be
showing a (-) value - energy is coming out of the battery.
Take a voltmeter reading.
Now, start the engine and turn the alternator on. Note the bus
voltage. We would LIKE to see 14.2 to 14.6 volts but 13.8 or 13.9
would still charge the battery.
After the alternator comes on, if you see a rise in bus voltage,
then the alternator IS working to some degree. Its set point may
be too low . . . but it is working. Now the ammeter should show
a decided (+) reading - energy is being stuffed back into the
battery. Turn all the accessories off and observe the ammeter
which should begin to move back toward zero indicating that the
battery is topped off.
For the moment, nothing you've written suggests that the system
is seriously malfunctioning. It may need adjustment of voltage.
Posted: Sun Sep 02, 2007 3:31 am Post subject: How to check and alternator?? |
Hi Bob !!
Thanks for the help and suggestions !! I really appreciate you and all I learn from you.
So, I did exactly as you said, and you are 100% correct. I left on a bunch of stuff for about 10 minutes, then started the plane and immediately noticed the ammeter was slightly on the negative side, maybe reading about 4 negative amps. The voltage read just under 15 volts - say 14.7 the whole time and stays there but within about 3 minutes, the ammeter came back up to zero and stayed there.
I wired the ammeter and external shunt as per Van's Aircraft instructions and my brother Danny (which you've all heard from many times) says there are 2 other ways (according to Dynon) to wire the ammeter which I might do.
I'm not sure of the best or correct way to wire the ammeter but at least now I know my alternator is working perfectly and THAT makes me happy.
Maybe I should leave it alone since I now know exactly what it's reading.
Thanks for your input and suggestions.
Matt
running.
which should begin to move back toward zero Luggage? GPS? Comic books?
Posted: Mon Sep 03, 2007 4:02 pm Post subject: How to check and alternator?? |
At 04:30 AM 9/2/2007 -0700, you wrote:
| Quote: | Hi Bob !!
learn from you.
Sounds like your ammeter is a bit big for the job and
it may be wired backwards too. Normally, one expects to see
a STRONG + reading while the battery is being replenished,
a near ZERO reading while the alternator is carrying ships
loads and the battery is charged, and a STRONG - reading
when the alternator is off and everything thing is turned
on. Your "slightly negative" observation while charging the
battery tells me it is too small and wired backwards.
