Posted: Thu Sep 06, 2007 1:07 am Post subject: Was Nothing new then now propeller twist |
Hi!Roger
No. Not that I could tell. Maximum 5 minutes and the coolant is too hot
to make a dash for it! I'm resigned to accept that at present, since
when flying it's fine. I get words of advice that after 10 to 50 hours
it runs cooler anyway.
I tried the half choke setting in flight yesterday and it made no
difference to coolant temps. I thought running richer would have had a
dramatic effect since the guys with a mixture facility can control their
burn really well.
Bob Harrison. G-PTAG
rparigor(at)suffolk.lib.n Guest
Posted: Thu Sep 06, 2007 2:54 am Post subject: Was Nothing new then now propeller twist |
Hi Bob
"I tried the half choke setting in flight"
I meant for you to try 1/2 to full choke on ground to try and cool things
down!
Actual it is not a choke but an enrichening circuit. It does nothing much
/ above idle to richen things up! Thus your inflight test is exact as I
would suspect.
Giveratry on ground and please report.
How does full course and 2500 (also try 3000 and 3500) RPM do (angled into
wind) to help cool?
Ron P.
Gilles.Thesee(at)ac-greno Guest
Posted: Thu Sep 06, 2007 9:36 am Post subject: Was Nothing new then now propeller twist |
Thilo Kind a écrit :
Hi there,
I'm flying a Zodiac 601 HDS with Rotax 912 with the water rad unerneath the cowling (original Rotax rad). Depending on the OAT the water temps start to climb to 220 F over a period of 10 minutes or so. During climb out I typically see 210 F. In cruise, the water temps drop to 140 F. CHT temperature on the other hand does stay pretty stable at around 100 F (it's a bit higher, since the sensor is not properly calibrated).
Can you give us more detail about your setup ?
Where and how do you measure water temp ? Radiator exit, radiator entry,
etc...?
Witch of the two CHT probes are you using, front, rear ? 100 F is
really not a working temperature for the the cylinder heads. You already
read that in a hangar on a hot day...
Something must be wrong....
Best regards,
Gilles
http://contrails.free.fr
Roger Lee
Posted: Thu Sep 06, 2007 1:52 pm Post subject: Re: Was Nothing new then now propeller twist |
I agree that 100F sounds way off. It has to be higher than that if the engine is running especially this time of year.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
ollie6a(at)embarqmail.com Guest
Posted: Fri Sep 07, 2007 5:08 am Post subject: Was Nothing new then now propeller twist |
Are you reading F* or C*
Ollie Central FL
On 9/6/07, Roger Lee <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote: [quote]--> RotaxEngines-List message posted by: "Roger Lee" < ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
Roger Lee
Tucson, Az.
