mark.stauffer1(at)gmail.c Guest
				 Posted: Sat Sep 15, 2007 6:22 pm    Post subject: Fuel tanks (sending unit concerns) |
				I've had to replace two units. Actually it's more of a pain to take the wing
 out than it is to remove the sending unit. Drain the tank, un-hook
 everything, pull out the spar and angle of incidence bolts and then pull out
 the wing. About an hour or so job. Then take a heat gun and start heating up
 the sending unit and the epoxy around it. It's takes a bit of work but you
 should have it out in about 10-15 minutes. Clean up the remaining epoxy and
 glass the new one in.
 A note about the sending units. Princeton claims a very low failure rate and
 we've had very good luck with them. I would suggest to you though that you
 test the units before you install them. If my memory serves me correctly non
 of our units failed during use, they failed the first time during
 calibration. In other words they didn't work when we installed them. Believe
 me, we've learned our lesson. All units are tested (calibrated) in a five
 gallon gas can before we install them. Once you have a successful
 calibration then just reset the unit to zero. All of the calibration steps
 are explained in the instructions sent with the units.
 Hope this helps.
 Mark
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
