l_luv2_fly(at)yahoo.com Guest
Posted: Thu Sep 13, 2007 2:07 pm Post subject: Installing new Rings in a 914 |
Hi all,
I purchased a 914 a year ago that had been run in a test cell for 100 hours and then it sat for a couple of years.
I pulled the heads to inspect for corrosion and found small amount on the valve seats so I had them re seated, however I decided since I have it in bits to put a new set of rings in it.
So, after such a long winded introduction I would like to know if it is required to hone the bores so that the new rings will seat, or would I risk damaging the coating on the cylinder bores ?
Thanks, Paul
">fall's hot new shows on Yahoo! TV. Watch previews, get listings, and more! [quote][b]
Roger Lee
Posted: Thu Sep 13, 2007 3:40 pm Post subject: Re: Installing new Rings in a 914 |
You can download the heavy maint. manual from the Rotax website for the 914 and it will tell you for sure.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
