jojatek86(at)yahoo.com Guest
Posted: Mon Sep 24, 2007 8:32 am Post subject: SYI Fly-In |
Robin and I had a great time visiting with everyone. I wish we could have stayed longer than just Saturday afternoon, but it was well worth the trip. It was good to hear Pete tell the history of the Lightning and then hear from Nick about all the new goodies on the way. My flight with Buz was a blast! I'll be working overtime to save up the money for a kit.
If you guys want to fly down to LZU for a pancake breakfast, EAA 690 puts on a nice spread first Saturday of each month. There's usually about 50 people at the breakfast and we usually have a speaker. Check www.eaa690.org for details.
Thanks to all the folks at SYI for putting on such a nice event.
Pat Phillips
Lawrenceville, GA
Luggage? GPS? Comic books?
Check out fitting gifts for grads at Yahoo! Search. [quote][b]
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
Posted: Mon Sep 24, 2007 7:11 pm Post subject: SYI Fly-In |
I tried to send this from work earlier today. I don't think it went through.
Pat
----- Forwarded Message ----
To: Lightning List <lightning-list(at)matronics.com>
Sent: Monday, September 24, 2007 12:28:09 PM
Subject: SYI Fly-In
Pat Phillips
Lawrenceville, GA
Building osting/?p=PASSPORTPLUS">all the tools to get online. [quote][b]
N1BZRich(at)AOL.COM Guest
Posted: Tue Sep 25, 2007 5:14 pm Post subject: SYI Fly-In |
I had a great flight back to Williamsburg, Virginia, yesterday, once again staying lower than I normally fly N31BZ, a modified Esqual with Lightning Stuff. However, one odd occurrence was having a headwind when on an easterly heading - very unusual. My initial cruising altitude of 5,500 had about 7 to 10 on the nose which changed to 12 to 15 on the nose when I climbed to 7,500 over the mountains. Later that went to 15 to 20 as I got further into NC and VA. Dropping back down to 5.5 did not help and gave the same headwind component.
Once again, my cross country technique is to set the fuel flow I am looking for and accept the rpm and airspeed this gives me. In this case, at 5,500 when I set 6.0 gph it gave me an rpm of 2950 to 3000 (the altitude hold causes the rpm to vary as it "flys" the airplane to keep the altitude constant) and the true airspeed was 155.9 mph. Actual fuel burn from start up to shut down (remember this would include start, taxi, run up, and climb to altitude) averaged out to 5.9 gph for the entire flight. Actual inflight fuel burn would probably be closer to 5.5 to 5.6.
Now having made numerous cross country flights in the 10 to 14 thousand foot area and several in the 4 to 8 thousand area, I am about ready to say that you can expect to average about 160 mph (140 kts) true when in the lower area and 170 mph (150 kts) true when in the higher altitudes. Fuel burn seems to be about the same in either altitude band. If you want to impress your non pilot friends, tell them that you get about 28 mpg at 170 mph. Their Nash Rambler won't get anywhere that at half the speed.
Blue Skies,
Buz
See what's new atblank">Make AOL Your Homepage.
pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Tue Sep 25, 2007 5:40 pm Post subject: SYI Fly-In |
Buz:
Is 2950 a typical cruise RPM? Is that running around 80%, and how does the 3300 like that RPM range?
Jim!
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of N1BZRich(at)aol.com
Sent: Tuesday, September 25, 2007 9:14 PM
To: lightning-list(at)matronics.com
Subject: Re: Fw: SYI Fly-In
Blue Skies,
Buz
| Quote: | | http://www.matronics.com/Navigator?Lightning-List | 01234
N1BZRich(at)aol.com Guest
Posted: Wed Sep 26, 2007 5:38 am Post subject: SYI Fly-In |
In a message dated 9/25/2007 9:42:13 P.M. Eastern Daylight Time, pequeajim(at)gmail.com writes:
Is 2950 a typical cruise RPM? Is that running around 80%, and how does the 3300 like that RPM range? |
Jim,
The short answer is yes, my engine seems perfectly happy at 2950. In fact, it seems happy running as high as 3150. That is the highest I have run it for extended periods. So for my airplane, engine and propeller combination all seems to be good at those rpms. My engine currently has about 365 hours total time in the past 21 months, and other than routine maintenance, it has been trouble free.
The prop I am currently running is a Sensenich 64-ZK-55, and it is not the right prop as it still allows my engine to turn up quite a bit over 3300 rpm at full throttle. Nick is also experimenting with different props and we look forward to trying a 62-FJ-58 on the prototype and N31BZ as soon at they arrive. The prototype is currently running a 62-FJ-56, and this blade profile seems better for the entire rpm range. It will still turn over 3300 at full throttle, but the big difference we see with this blade profile is that the rpm is up on takeoff roll and climb out which results in shorter takeoff rolls and higher rates of climb. The extra pitch should allow a higher top end or the same speed at a lower rpm and thus less fuel flow. It remains to be seen if we will need to once again adjust the carb jets to optimize performance with the new prop. Along this line, Don in Australia has done some great experimenting putting a Revmaster throttle body injector on the 3300. In the long run, that may turn out to be the way to go, as it gives additional rpm and with a manual mixture control is more efficient at the higher altitudes.
Blue Skies,
Buz
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
