a58r(at)verizon.net Guest
Posted: Tue Sep 25, 2007 11:48 am Post subject: Primer |
My 4-pharty-7 used to take 5-6 smart pulls to start, but after T-ing
one of Mark Smith's tiny primers into fuel line coming out of tank,
and one or two thumb-pushes of the primer, she(?) starts on first
pull. The primer is a black rubber(?) half dome, less than an inch
dia./high. Not wanting to run fuel lines way up to the IP, I mounted
it on a small bracket abt shoulder high on the rt. cage "vertical"
diagonal. Too short in arms to reach panel anyhow. And line goes
directly to carb throat, through existing fitting.
regards,
Bob N. FireFly 070 Old Kolb
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Sat Sep 29, 2007 10:24 am Post subject: Re: Primer |
Bob:
Can you post a picture of the primer you described above and a contact number for Mark Smith?
Thanks, Do Not Archive
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
planecrazzzy Guest
Posted: Sat Sep 29, 2007 11:16 am Post subject: Re: Primer |
I used to have my primer line Tee'd off of my fuel line....
But the more I thought about it , I decided it wasn't a good idea...
So I've got it running in a separate system of it's own....
Gotta Fly...
Mike & "Jaz" in MN
d-m-hague(at)comcast.net Guest
Posted: Sun Sep 30, 2007 6:14 pm Post subject: Primer |
At 02:24 PM 9/29/2007, R. Hankins wrote:
...a contact number for Mark Smith?
Mark's mainly a Quicksilver guy, his website is http://trikite.com/ .
-Dana
"I'm a lawyer." "Honest?" "No, the usual kind."
