cdewey6969(at)yahoo.com Guest
				 Posted: Thu Oct 04, 2007 5:34 pm    Post subject: No luck with AOPA |
				Just wanted to let everyone know aopa insurance
 services don't underwrite insurance for the us virgin
 islands and couldn't recommend me to anyone. Still
 trying to figure out what to do as that is where I
 will be living and it sure would be nice to have my
 Lightning there. is anyone else out there in odd
 places in the world having troule getting insurance?
 Charles
 --- Brian Whittingham <dashvii(at)hotmail.com> wrote:
  Doug, Laurrie, any others interested,I have made
  this CFI lesson plan to be generic or non-aircraft
  specific. I don't have 20,000 hours in aircraft, but
  this was stitched together from various publications
  by many pilots who did. I would imagine that there's
  over a million hours of combined experience in this
  document! Check it out, see what you think.
  Hopefully I have minimized gramatical errors. I have
  references to personal experiences in there that
  might not be fleshed out as I tell them from memory.
  I haven't finished it all, as you can see there are
  a few through the list that I haven't posted
  anything under, and last 10 topics or so on survival
  equipment and survival in different environments
  isn't finished. I have about 58 pages of text to
  reduce down and make something useful out of when I
  get around to it. Maybe someday this will help
  somebody out, Brian W.Reference AC 61-67C Stall &
  Spin Awareness"Don't drop the aircraft in order to
  fly the microphone” = Aviate, Navigate,
  Communicate"Rule one: No matter what else happens,
  fly the airplane." = You are allowed to break any
  regulation needed in order to make a safe landing.
  If it comes down to it, you may have to sacrifice
  Navigation and Communication in order to crash into
  the softest thing possible."Fly it until the last
  piece stops moving." = The flight isn’t over until
  the prop stops moving, the aircraft is at rest, and
  the aircraft secured."If you're faced with a forced
  landing, fly the thing as far into the crash as
  possible." - Bob Hoover = Never give up! Flying,
  under control, into a brick wall is better than
  letting the aircraft loose control even for one
  second in an emergency. Engine Failure, 3 S’s:
  Speed--Spot--Set-up: Establish best glide Speed
  without delay. Select and head toward a suitable
  landing Spot. If time and altitude permit, Set-up
  for the landing by configuring the airplane
  according to the operating handbook. If you're
  landing off-airport, don't forget to prepare the
  airplane so you can get out of it once it's on the
  ground. Consider opening or even jettisoning the
  door or canopy prior to landing.Before Beginning a
  Maneuver: FOUR A's - Altitude, Articles, Aircraft,
  Airspace: Be sure you have enough Altitude to begin.
  Factor in the maneuvers to be flown, your current
  level of proficiency and physical conditioning, and
  an adequate safety factor. Verify that all loose
  Articles are secure--this includes windows, doors,
  canopies, and occupants! Verify that the Aircraft is
  configured properly--mixture, switches, engine
  instruments, carburetor heat/alternate air, flaps.
  Clear the Airspace for other traffic and make sure
  you're complying either with the provisions of FAR
  91.303 or a waiver for the area.Best Defense• The
  old adage of the best defense is a good offense when
  we’re talking about aircraft emergencies holds
  true• The right mindset and the right training
  will generally allow for an uneventful landing that
  may have otherwise resulted in a fatal accident. •
  Let's face it, sitting on the ground is the time to
  figure that out because if you haven't thought about
  it before it happens you may not be in any mental
  condition to rationally consider your options.•
  TAKE PREFLIGHT SERIOUSLY!• Really check the
  controls to make sure that they move freely and in
  the proper direction. Listen and feel for anything
  unusual such as binding or scraping• Be sure that
  everything in the cockpit is stowed away in an
  orderly place so that in an emergency, you won’t
  be looking for that map, so that in the event of
  turbulence you don’t have something hit you in the
  head or eye, and so that nothing is rolling around
  that could jam the controls• Put down the flaps
  and, if they're electrically actuated, listen to the
  motor as they extend and retract. If the flap motor
  is struggling on the ground, it's likely to have
  real problems when it must overcome the aerodynamic
  pressure of the relative wind. If they are manually
  operated make sure that they both extend as
  commanded and that there is no binding or abnormal
  resistance.• Don't panic. Do fly the airplane!•
  Use the 3 prong strategy in an emergency, your
  training will take over, but may times your initial
  instinct will be the wrong action to take, so take
  your time.1. Do Nothing2. Think3. Act• When I take
  off, I assume I'm going to have to abort. If you put
  yourself in that mind state, you're ready for things
  to happen. Pilots should use the quiet moments
  during flight to ask themselves the what-if
  questions — where would I put down if my engine
  failed? What would I do if my rudder jammed?• I
  constantly asked myself, where I would put down if
  the engine failed, what if my aileron jams at this
  point. I would takeoff using a Vy climb to put me in
  a better position if my engine failed on takeoff. I
  often use a short field takeoff. I often do a full
  power off approach from downwind so that I’d have
  a feel that I could make it if my engine failed on
  landing. Delivering aircraft, or flying cross
  country, I would mentally plan to land at the next
  airport each time in case the weather was getting
  bad, never forgetting to turn back to the last if
  the weather was getting worse ahead. I also
  constantly updated weather for the next point in
  question. In addition I picked out fields along the
  way to land in if I had to at that exact moment in
  time and couldn’t make it back to an
  airport.Communications Failure• Are your comm
  switches set in the right positions?• Is the
  volume up?• Do you hear yourself when you try to
  transmit?• Check your headset plugs to see if
  they’re all the way in and not corroded• Switch
  headset or mic• Try speaker mode• Switch to comm
  2• Check to see if your battery is discharging or
  see if your alternator is working.• If on IFR
  flight plan but not IMC, land at nearest VFR
  airport; stay VFR• Squawk 7600, transmit
  intentions “in the blind”• Use AVE-F if in
  IMC, Assigned, Vectored, Expected, FiledTransponder
  Failure• Check to make sure that it is in the
  correct position (alt)• Does the interrogation
  light illuminate?• Recycle it – power off, power
  on• Try switching through different codes and then
  back to your original (take care to avoid codes such
  as 7500, 7600, 7700, and 7777)• Hit the faceplate
  (no really, this is in some POH’s, and
  works!)Doors Opening In Flight or seatbelt stuck in
  door• Maintain control of aircraft, fly the
  plane• When at a safe altitude, slow the aircraft
  down and push out on the door followed by pulling it
  in and trying to latch it• If this doesn’t work,
  make a normal landing and worry about it on the
  groundPitot-Static Failures• Pitot static failures
  can come from a number of things such as ice, bugs,
  breaks in system lines, tape over static ports
  during painting or washing planes, etc.• A good
  preflight will help make sure that these systems
  aren’t clogged on the ground.• During the
  takeoff roll, make sure the airspeed is coming alive
  and gauges are in the green. Ask yourself if the
  airspeed “feels” right. If the airspeed isn’t
  coming up fast enough, abort. • In flight if you
  have a failure, try to determine the cause. An
  clogged pitot tube will cause the airspeed to drop
  to zero while a clogged pitot and static will cause
  the airspeed to work as an altimeter, giving reverse
  expectations such as increasing speed in climb and
  decreasing in descent. The sounds of the air outside
  should be clues to whether you’re actually
  increasing or decreasing in speed. A blocked static
  port only will cause the Altimeter to freeze while
  the airspeed will overreport values.• When
  dewpoint and temperature are close together, if the
  humidity is high, even if the temperature is not at
  freezing, the pitot can pick up ice. If equipped,
  turn on the pitot heat. (note, if also having
  alternator issues, this can drain the battery which
  may be used for flaps, lights, gear, etc. depending
  on aircraft. Use good judgment. If equipped and have
  to use pitot heat while discharging battery, drain
  backup battery first)• Switch to alternate static
  source if equipped, using POH to determine altitude
  error. If not equipped, breaking the glass on a VSI
  can act as an alternate static source.• When
  landing with inaccurate airspeed, ask yourself if it
  “feels right”. Use clues such as RPM increasing
  in descents and wind noise outside. Carry extra
  airspeed in landing and use full recommended flaps
  to lower stall speed. Consider a straight in
  approach and be sure to be established with
  attitude, configuration, and rpm set with plenty of
  altitude. This will fix your airspeed within a
  certain speed range and provide some additional
  protection. GPS Failure• In this day and age we
  have come to rely on the GPS too much• Fly every
  flight as though you were going to dead reckon the
  entire way. • Use other navigation aids, be sure
  to identify station if using VOR or NDB systems•
  It has been said that many aircraft in the future
  may go back to using LORAN as a backup for GPS, and
  may become integrated into the system so that you
  know that your GPS has lost integrity and went into
  LORAN mode. This essentially works like a GPS.•
  Use the GPS as you would a VOR, noting distances
  from various airports or identifying marks. Mentally
  overlay this on a Sectional, possibly making updated
  marks on the Sectional along with noting the time.
  • If the unit fails, calculations can be made for
  speed time and distance to find your way.• Dual
  GPS units will allow for a malfunction of one
  system, but not a loss of satellite signal
  integrity• If you loose a minimal amount of
  satellites, the system will eventually come back,
  but in the meantime you navigate by other means•
  Don’t be too proud to ask ATC for help with a DF
  SteerAHRS Failure• Check that AHRS Circuit
  Breakers are in• Use standby instruments• If in
  a cloud and have the ability, used a timed 180
  degree standard rate turn• If attempting a reset
  in
 === message truncated ===
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
