Switched hot bus
jason.rouault(at)hp.com
PostPosted: Wed Oct 03, 2007 7:39 am    Post subject: Switched hot bus Reply with quote
All—
I am currently working on my wiring diagram for my FADEC equipped plane. I will be using a slightly modified version of the Z-14 diagram. I found a fellow builder with the same setup as me and got a hold of his wiring diagram. Attached is a snippet of that diagram. My question pertains to the guarded switch for FADEC bus #1 (there is a similar setup for FADEC bus #2). The diagram is showing 4 AWG wire between the battery and guarded switch. Shouldn’t there be a relay or something here?
Jason
 Filesize:  35.57 KB
 Viewed:  223 Time(s)
zk-vii(at)rvproject.gen.n
PostPosted: Wed Oct 03, 2007 12:04 pm    Post subject: Switched hot bus Reply with quote
Hi Jason,
I'm guessing that is a typo. The ECUs require about 7amps if I recall (although I don't know if that is each or both), HSA / SSA are low level signal elements - being real generous I don't think more than 15 ish amps will be required for continuous duty. Obviously depending on wire length, something like AWG 14 should be in the ball park.
Now the question of will the switch handle that current - different problem...
HTH,
Carl
ZK-VII - RV 7A QB - finishing? - New Zealand
http://www.rvproject.gen.nz/
[quote] --
 Filesize:  35.57 KB
 Viewed:  215 Time(s)
