pcasson(at)sasktel.net Guest
Posted: Mon Oct 08, 2007 2:59 pm Post subject: Another RV-10 in the air |
Hi All,
Very pleased to report RV-10 C-FMHP flew it’s first flight this afternoon.
Couple snags including a light turn to the left at cruise and a transponder not reporting altitude but overall seems to be a great airplane.
Keep smashing those rivets, it’s well worth it!
Perry Casson
RV-10 C-FMHP - TTSN 42 min.
Regina, Canada
http://casson.2y.net/rv-10
coop85(at)cableone.net Guest
Posted: Mon Oct 08, 2007 3:14 pm Post subject: Another RV-10 in the air |
Perry,
Congratulations!!! I know you are elated over your accomplishment.
On the left turn, before you get too excited about tweaking anything, if it’s very light it could be that it’s you causing it and not the airplane if you have equal fuel in both tanks. If I’m not using the autopilot I am very sensitive to which tank I burn out of for roll trim and I start with the left side if solo. Just a consideration of course it could be something else.
On the transponder, if you have a Garmin 327 I had some issues as well and was told by the folks at Stein where I bought it the pin in the back that transfers the altitude data to the XPDR is finicky to say the least. Others haven’t had an issue but getting the pins seated properly might help.
Best of luck with the test hours,
Marcus
40286 – 200 hrs and the bird is finally getting painted.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry Casson - Home
Sent: Monday, October 08, 2007 6:00 PM
Subject: Another RV-10 in the air
Hi All,
Perry Casson
Regina, Canada
rene(at)felker.com Guest
Posted: Mon Oct 08, 2007 3:19 pm Post subject: Another RV-10 in the air |
Congrats……where are the pictures? I want to see the smile…
Rene' Felker
N423CF
40322
801-721-6080
Sent: Monday, October 08, 2007 5:00 PM
Hi All,
Perry Casson
Regina, Canada
Posted: Mon Oct 08, 2007 5:43 pm Post subject: Another RV-10 in the air |
CONGRATULATIONS! I would also like to see pictures, as would most of the other people on the list I’m sure. Enjoy it.
On the slight turn at cruise, does it happen when you raise your flaps from climb setting to cruise setting? I have seen that before and it could either be cause by a very slight twist in the flaps or one being a little higher than the other. The best way to see that you don’t have a twist in the flaps is to raise them all the way up and compare the spar rivet line with the top skin on the wing. It is a very easy way to see how straight your flaps are (ask me how I know).
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: Perry Casson - Home [mailto:pcasson(at)sasktel.net]
Sent: Monday, October 08, 2007 7:00 PM
Hi All,
Perry Casson
Regina, Canada
Posted: Mon Oct 08, 2007 6:16 pm Post subject: Another RV-10 in the air |
| Quote: | CONGRATULATIONS! I would also like to see pictures, as would most of the other people on the list I’m sure. Enjoy it.
[Perry Casson]
Didn’t want to waste bandwidth attaching a photo, the following link takes you to a little web site that has about 150 of them
Sorry no rv grin shot, the ground crew got bored waiting for me to land and went flying themselves it was such a perfect fall day.
Perry
wayne.e(at)grandecom.net Guest
Posted: Tue Oct 09, 2007 3:18 am Post subject: Another RV-10 in the air |
Congratulations on getting airborne for your first flight. It's a great feeling when you get to that day but then you land a realize that you still have a lot of work left to do :>} But it's a lot easier when you know you can take it back up for another spin.
Good luck on your fly off eh
Wayne Edgerton N602WT
flying do not archive
