		rbittner(at)us.ibm.com Guest
				 Posted: Fri Oct 12, 2007 8:15 am    Post subject: Yaesu VXA-100 external PTT |
				Hi.
 I have a Yaesu VXA-100 and the Yaesu external headset adapter cable.  The standard PTT switch (which works fine with other radios & intercoms) does not work on this handheld/cable combination. It does not trigger tx.
 Is anyone out there using a Yaesu handheld radio with an external PTT?
 Do you have a wiring diagram that shows how to hook in an external PTT?
 Thanks.
  Bob Bittner
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Rhino
				 Posted: Wed Oct 17, 2007 12:22 am    Post subject: Re: Yaesu VXA-100 external PTT |
				[quote="rbittner(at)us.ibm.com"]Hi.
 Thanks.
  Bob Bittner
   Bob,
 Yaesu tends to use standard connectors, so the pinout diagram for their standard 8 pin microphone connection should work in your case. Luckily, Yaesu makes ham radios as well, so several ham sites have pinout diagrams for their radios. Try this link. The 8 pin diagram is the second entry in the table of contents. Hope this helps.
 http://hamradio.online.ru/ftp3/All_YAESU_mods_from_mods_dk_in_ONE_file.pdf
		dstroud(at)storm.ca Guest
				 Posted: Wed Oct 17, 2007 4:40 am    Post subject: Yaesu VXA-100 external PTT |
				These people may have to info or what you need, Bob.
 http://www.wingsandwheels.com/page6.htm
 I've been running
 a Yaesu vxa-100 for many years in my current ride but I cannot
 remember exactly how I got the PTT to work. There are only three inputs to
 handheld though, antenna, external power and the Headset adapter line
 wherein I think you'd find the PTT attach point. I think the PTT line just went
 from the adapter to the switch and then to ground. They've got the headset
 adapter thing for $44 but may part with the info only if you've got the plug etc.
 By the way, my old vxa-100 is the aviator PILOT model with VOR capability
 so they said. What Yaesu did not tell it's customers is that the VOR
 capability only works from a vehicle in a stationary postition. Kripes.
 When we bitched vehemently to their head office in California, they advised
 that an acceptable solution would be to take the unit back to where you bought
 it and upgrade (at your own cost) to the next higher model. Hmmm.....
 David Stroud   Ottawa, Canada
 C-FDWS  Christavia
 Fairchild 51 under construction
		akfotoman
  Joined: 19 Apr 2006 Posts: 120 Location: Anchorage, Alaska
				 Posted: Wed Oct 17, 2007 7:51 am    Post subject: Yaesu VXA-100 external PTT |
				I am using the VXA-700 and it has its own screw in micro connector that goes
 from the radio into an RCA coupler/splitter, which then goes into a FlyteCom
 mixer box, and then to a separate push to talk.
 My two cents worth.
 It would not work with other set ups, or with Dave Clark helmets, only the
 Fcom set up.
 Rob
  _________________ Have cameras, will travel! |
