wb2ssj(at)earthlink.net Guest
Posted: Sat Oct 13, 2007 2:26 pm Post subject: engine mount sage |
Has anyone checked to see if your engine has sagged any sense installation? I am about to fit my cowl and would like to compensate for any if its prevalent.
Tex
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Sat Oct 13, 2007 3:02 pm Post subject: engine mount sage |
Tex:
I asked that exact question at Arion today. They install the engine with no shims and then if for some reason, it sags, shim it accordingly. Fit the cowl for a straight install, no shims. I installed my engine with no shims, but allowed for a tiny bit of sag.
On 10/13/07, Tex Mantell <wb2ssj(at)earthlink.net (wb2ssj(at)earthlink.net)> wrote: [quote] Has anyone checked to see if your engine has sagged any sense installation? I am about to fit my cowl and would like to compensate for any if its prevalent.
Tex
vettin74(at)yahoo.com Guest
Posted: Mon Oct 15, 2007 7:26 am Post subject: engine mount sage |
Fit the cowl with no shims ...the rubber moutns settle in after 35-40 or so and you may have to put a shim under the bottom mounts to compensate...but do not do this to start as it will initially change the thrust line and if the cowl is fit to that it will not fit later.
nick
Jim Langley <pequeajim(at)gmail.com> wrote:
[quote] Tex:
On 10/13/07, Tex Mantell <wb2ssj(at)earthlink.net (wb2ssj(at)earthlink.net)> [quote][b]
