rge177(at)yahoo.com Guest
Posted: Sat Oct 13, 2007 6:17 pm Post subject: Jab Cowling issue |
I ran into a small Jab 3300 cowl issue last week.
The cabin heat NACA vent on the cowl, which I thought
was going to be on the left side of the cowl, was on
the right side of the cowl, and was only a 2". The
heat muff that I recieved was a 2" on the side that
goes to the cabin heat box, but was a 2 1/4" on the
side that connects to the NACA vent. USJabiru was
quick to send a new heat muff that has 2" ports on
both sides, along with extra scat tubing because now
the air will enter from the right side of the cowl,
into the right side heat muff, out the left side heat
muff, and then have to be routed back to the right
side firewall where the cabin heat box is mounted.
You may want to check your cowl and heat muff when you
get them so you won't have any surprises when you
start working on that part.
Ron
Haslet, TX
601XL-3300
http://smallbusiness.yahoo.com/webhosting
