pwmac(at)sisna.com Guest
Posted: Fri Oct 12, 2007 6:17 am Post subject: Elevator Control Tube Guide Bushing (Lubrication) |
I suggest rubbing a candle on the cable. It will not attract
dirt/dust and is compatible with the nylon. I use this for many
a[pplications. It is not permanent but seems long lasting. No harm in trying it
Paul
At 05:03 AM 10/12/2007, you wrote:
When adding lubricant you will likely be adding something that will
attract dust, dirt etc which can become abrasive.
I think it is just a guide more than a actual tight fitting bushing.
Is it binding now ? You should be able to move stick full aft and
let go to have the stick return full forward. If not something
could be binding.
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=139535#139535
