apeterchristensen(at)sbcg Guest
Posted: Sat Oct 13, 2007 1:18 pm Post subject: Kitfox/Railroad Container Question |
Does anyone know if a 40'X8'X8' railroad container could be used as a hanger
for a folded wing Kitfox? Cheap storage if it would.
Pete
dave
Posted: Sat Oct 13, 2007 2:44 pm Post subject: Re: Kitfox/Railroad Container Question |
you should need about 22 feet long or so
7'10" wide about
under 6 feet tall if on wheels.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
rliebmann(at)comcast.net Guest
Posted: Sat Oct 13, 2007 3:03 pm Post subject: Kitfox/Railroad Container Question |
Yes it would...;>) Ron N55KF
shinco(at)bright.net Guest
Posted: Sat Oct 13, 2007 4:49 pm Post subject: Kitfox/Railroad Container Question |
I do not see why not it would not work,,but would be ugly..but different
and cheap.would not blow away easy.no up keep.last for ever.launch a
Kitfox from a train car? humm?why not?may B even have a flat bed train
car.and use it to take off+land on it too.would be a cheap airport.
good luck on your project.hope that it works out for you. Steve
S,KF2,N554KF
Pete Christensen wrote:
<apeterchristensen(at)sbcglobal.net>
hanger for a folded wing Kitfox? Cheap storage if it would.
Pete
Float Flyr
Posted: Sat Oct 13, 2007 4:59 pm Post subject: Kitfox/Railroad Container Question |
My garage door is 10' high and I have to be careful when putting my plane,
on floats and a low trailer in the garage.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
pwmac(at)sisna.com Guest
Posted: Sat Oct 13, 2007 7:41 pm Post subject: Kitfox/Railroad Container Question |
Mine is 92" wide and 89" high inside measure. I used it to store my
plane during the move and now I use it for cheap storage. Its the
cheapest secure storage you will ever find. One drawback is no temp
control. The metal gets much hotter than ambient and much colder than
ambient. Thus one has to be selective as to what goes in the metal
box. As you might have noticed the Kitfox wont fit with the wings
attached even folded or with the horiz attached. Mine is a 40' and
has doors on both ends . Very handy.
Buy or build a box trailer that is over width. Cheapest would be to
make your own. Park it at the airport next to a friendly hanger
owner. The white metal wont have the temp excursions that the steel
cargo container has. Not as secure since anybody with a saw can open
it up on the sides. This solution definitely needs tiedowns because
it is so light. I see 5th wheel trailers parked at different airports
so I know it is possible. Make one that is 10' wide and 30+ feet long
that is not very road worthy. Then sneek it to the airport in the
dead of night to avoid the cops since you will not be highway legal.
Jack it up a so the cheep tires and axles do not carry much weight.
Leave the tires on it so it still looks like a trailer. Put a big
fuel tank in the trailer for ease of fueling or de-fueling.
Have fun,
Paul
At 03:17 PM 10/13/2007, you wrote:
a hanger for a folded wing Kitfox? Cheap storage if it would.
Pete
RRTRACK(at)aol.com Guest
Posted: Sun Oct 14, 2007 4:28 am Post subject: Kitfox/Railroad Container Question |
Depends on what model Kitfox you have and the door opening size of the container. My Kitfox V would not fit as the horizontal stabilizer, elevator, folded wings, and landing gear are all to wide.
Also metal containers would be subject to condensation inside with temperature changes.
Mark
Kitfox 5 Vixen
912UL IVO
Hartford, Wisconsin
See what' [quote][b]
Float Flyr
Posted: Sun Oct 14, 2007 6:12 am Post subject: Kitfox/Railroad Container Question |
No problem. put up vapour barrier inside the container and insulate the outside with siding. Or get an old transport trailer with plywood interior.
Noel
Mark
Kitfox 5 Vixen
912UL IVO
Hartford, Wisconsin
Kitfox III-A
dave
Posted: Sun Oct 14, 2007 12:29 pm Post subject: Kitfox/Railroad Container Question |
Now there is an idea! Sounds like the container won't work. I'm sure a
slightly oversize trailer might be the way to go. At 5t6 a shaded tie down
is $40/month and the airport mgr said I could put a trailer there.
Pete
rexinator(at)gmail.com Guest
Posted: Sun Oct 14, 2007 6:57 pm Post subject: Kitfox/Railroad Container Question |
I had looked at an ocean shipping container (which I think may be the
same thing) and, if I remember correctly, determined that the
measurements are the exterior size. That means the interior measured
less than 7' 10" which is the width of my Model 2 folded and it would be
just about impossible to slip the airplane into one with the wings on.
Have you measured the doorway and interior of this container? Having
stored my M2 in an old single car garage with one wing removed because
the doorway way only 7" 10" it was still a careful exercise to move it
in and out as the tail is almost that wide.
I agree they are very good quality and secure ( unless a thief has
access to a semi tractor and container transport rig).
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Pete
Float Flyr
Posted: Mon Oct 15, 2007 6:05 am Post subject: Kitfox/Railroad Container Question |
FYI,
The company I bought my container from welds a metal box at the
locking place. The result is bolt cutters wont reach the lock. To
open the lock one has to get the feel for one of those round locks.
The bad guy has to have a cutting torch to get the door open. Its
probably easier to use a metal saw and just cut the side open.
Conclusion, very secure.
I noticed that one has to pick the correct container because some
have a smaller door openings than others. My measurements (92") was
the door openings.
Paul
At 05:54 AM 10/15/2007, you wrote:
The idea of using a container for storage is a good one. Most of them are
reasonably well sealed and if needed can be lined with plywood. I checked
around for a price on a well used model and the cost was prohibitive.
As for secure, my grand father used to say that a lock is only to tell an
honest man there's nobody home. Any one wanting to get into a container can
get in fast with a set of bolt cutters or at most a portable oxy fuel torch.
The up side is you would have a great natural wall for a mural and the top
could be converted to a nice sun deck
Noel
JSD
Joined: 08 Jun 2006 Posts: 11 Location: Hahns Peak,CO
Posted: Mon Oct 15, 2007 5:45 pm Post subject: Re: Kitfox/Railroad Container Question |
I was thinking about a shipping container awhile back and determined that it wouldn't be wide enough. Here's another thought. You could get a junked 10' wide mobile home very cheap on wheels and cut it down to trailer size or just cut the frame down and build your own walls anyway you want. Leave enough room inside to store odds & ends with the plane. Steel up any windows and make it look like a trailer (not a mobile home) to avoid any complaints from neighbors/county etc. It might not be as secure as a container but if they're determined enough they'll get into anything. Anyway this might beat having to go through the building dept. & all to build another garage.
_________________ Scott Denniston
K-7/ no power yet
65% or so complete |
