Tim(at)MyRV10.com Guest
Posted: Mon Feb 20, 2006 5:00 pm Post subject: Small clearance between nose wheel valve stem and nose whee |
Just checked mine tonight for you. I never really noticed it
before, but with the cap on, mine has very little (1/16" or
maybe 1/8" if I'm real lucky) clearance when it turns.
Haven't had a problem, but yeah, it sure is close.
Tim Lewis wrote:
RV-10 list,
On my RV-10 nose wheel I'm finding that the valve stem (with the valve
stem cover off) misses the nose wheel fork by only 1/8". If the valve
stem cover is on, the valve stem cover hits the nose wheel fork when the
wheel is rotated. Is this what others are seeing?
