Edwardoconnor(at)mac.com Guest
Posted: Mon Feb 20, 2006 8:11 am Post subject: Cockpit Light Bulb |
I just wanted to find out if anyone knows a source for a 12 volt # 313
bulb. I have a cockpit map light from a F-100 I acquired many years
ago and I thought I would check to see if I can rig it up in my RV.
Aircraft Spruce has the 313 but it only lists it in a 28 volt version.
Maybe there is a substitute that will work in 12 volt.
Ed O'Connor/ RV-8 N-366RV/ awaiting first flight.
dburton(at)nwlink.com Guest
Posted: Mon Feb 20, 2006 8:43 am Post subject: Cockpit Light Bulb |
| Quote: | I just wanted to find out if anyone knows a source for a 12 volt # 313
Hi Ed,
Start here for bulb information:
http://www.donsbulbs.com/cgi-bin/r/b.pl/313~ac%7cdelco.html
A 313 is 28 volts by definition. You should be able to find a 12 volt bulb
that will work. It will have a different part number of course. If you
don't want to try and figure out the bulb for yourself, call Bulbman and ask
them for help...
Good luck,
Dave
dbris200(at)sbcglobal.net Guest
Posted: Mon Feb 20, 2006 9:06 am Post subject: Cockpit Light Bulb |
Ed,
A #313 is a 28V lamp, there is no 14V version. However a #1893 should be
pretty close to the same output and they are both size T-1 3/4. The 1893
won't be quite as bright.
Any decent electronics store should have them (probably not R.S.) or
Mouser Electronics has them
http://www.mouser.com/
Dave
Ed OConnor wrote:
Posted: Mon Feb 20, 2006 6:27 pm Post subject: Cockpit Light Bulb |
Ed, find out what the wattage is for the 313, Go to the aviation
section of your local auto parts store and see if you can find a 12V
bulb with the same base, wattage, and physical size (if the present bulb
is a tight fit). You might be able to find a table on the I'net that
will list all the bulbs and their specs. There is no #313 bulb in 12V
because the number is for a 28V bulb.
Ed OConnor wrote:
DOUGPFLYRV(at)aol.com Guest
Posted: Mon Feb 20, 2006 6:46 pm Post subject: Cockpit Light Bulb |
There is a #330 I think in 12V but don't know about physical size.
dp
DO NOT ARCHIVE
Paul LeDoux
Posted: Tue Feb 21, 2006 4:10 am Post subject: Cockpit Light Bulb |
Hi,
In the Newark catalog they list the followin numbers as 14 VDC lamps with the
same base, T3 1/4:
756
1813
1815
1893
Hope this helps, might find some in auto parts.
Paul
QB RV-8
