dlm46007(at)cox.net Guest
Posted: Mon Nov 05, 2007 6:38 pm Post subject: drilling F1001N-R and L |
Since the pin in these hinges is undersized to allow for the bending of the hinge, there is fore and aft play in the hinge. When drilling the aft end of the top cowl, is the hinge drilled when played forward or aft?
VHMUM(at)bigpond.com Guest
Posted: Mon Nov 05, 2007 11:54 pm Post subject: drilling F1001N-R and L |
You drill it with the full size pin in otherwise you will not get the other pin in or dificult to get it in.
regards Chris 388
