echristley(at)nc.rr.com Guest
Posted: Fri Nov 09, 2007 8:11 am Post subject: Antennae connector |
I'm buying a used transponder that does not have the atennae connectory
on the rear. This is the type that locks into the mounting tray with a
clip ring, and the coax exits out the side. Is there a proper name for
this connector? Where could I obtain just one?
nuckolls.bob(at)cox.net Guest
Posted: Fri Nov 09, 2007 6:41 pm Post subject: Antennae connector |
At 09:19 AM 11/9/2007 -0500, you wrote:
<echristley(at)nc.rr.com>
I'm buying a used transponder that does not have the atennae connectory on
the rear. This is the type that locks into the mounting tray with a clip
ring, and the coax exits out the side. Is there a proper name for this
Sounds like the slip-fit coax connectors
crafted back in the 60's to allow a radio
to be easily removed from the panel for
maintenance leaving the harnesses attached
to the tray. See if this isn't the critter
you're looking for:
http://www.aeroelectric.com/Pictures/Connectors/Coax/TED_9-30-10_A.jpg
No doubt the supplier listed is but one of
many. Do a net-search on "TED" and "9-30-10" and
see what pops up.
P.S. Here's one:
http://tinyurl.com/ynswar
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
Posted: Fri Nov 09, 2007 10:17 pm Post subject: Antennae connector |
you're looking for:
see what pops up.
Posted: Sat Nov 10, 2007 9:12 pm Post subject: Antennae connector |
<nuckolls.bob(at)cox.net>
> connectory on the rear. This is the type that locks into the
> mounting tray with a clip ring, and the coax exits out the side. Is
> there a proper name for this connector? Where could I obtain just one?
you're looking for:
see what pops up.
That's it. Thanks, Bob.
Posted: Sat Nov 10, 2007 10:05 pm Post subject: Antennae connector |
Sounds like what I've got on the back of my SL-70.
If it is, Garmin-AT will probably sell you one for an arm and a leg.....
Otherwise - I don't know....
Regardless, I may be looking for the same thing as I am having some trouble with my SL-70 and want to do some testing.......
Ralph Capen
Posted: Sat Nov 10, 2007 10:44 pm Post subject: Antennae connector |
| Quote: | I'm buying a used transponder that does not have the atennae connectory on
you're looking for:
see what pops up.
P.S. Here's one:
