dean.psiropoulos(at)veriz Guest
Posted: Sat Nov 10, 2007 11:57 pm Post subject: Magneto and VM1000 Dimming |
Functional checkout of my (Nuckolls inspired)electrical system has gone well
so far with no smoked wiring or equipment. I bought an equivalent of an
Odyssey 680 a couple years ago and trickle charged it occasionally hoping it
would at least be good enough to do electrical checkout, first engine start
and maybe a few times around the pattern. But it appears that is not the
case. Voltmeter says there is 12.5 volts at the terminals but it can't
produce enough amps to fire the battery contactor or even make some sparks
when shorted, pretty pathetic. I substituted a Panasonic 4.5 amp hour sealed
lead acid battery that I bought second hand about 6 years ago. It's got
enough oomph for the checkout but I'll need a new 680 for 1st engine start.
I did a test on my magneto P-lead (one mag on left side, electronic on right
side)with an ohm meter. Thinking that when the key switch is in the off
position, the resistance across the p-lead should measure close to dead
short and, it does. By the same logic, I thought that when the mag was
ungrounded the resistance across the pleads (I used a shielded wire with the
shield grounded at the magneto through the key switch as Bob recommends, no
local grounding). But when I measured across the p-leads at the magneto the
resistance only went from 0.2 ohms to 0.4 ohms when I turned the key. Not
an appreciable increase in resistance but it was consistent (happens every
time) and measurable. I thought maybe I had a faulty key switch but not so,
I removed one p-lead from the mag and made the same measurement and the
resistance with the key in that mag's position read infinite. I suspect
that there is some thing about magnetos I don't know and that this is not a
problem but would like to be sure. Anybody ever done this test? Did you get
the same results?
Also checked out the VM-1000 and it seems to work fine except for dimming.
I used one of the B&C dimmers connected to the VM-1000 dimming input but I
don't seem to get any dimming action (backlight works ok). Anyone else
experience this? Have I missed something in the VM manual and it doesn't use
an external dimming input? Any thoughts? Thanks.
Dean
RV-6A N197DM
closer to 1st flight.
Bruce(at)glasair.org Guest
Posted: Sun Nov 11, 2007 1:08 am Post subject: Magneto and VM1000 Dimming |
Yea, I believe the VM1000 only dims from the front panel.
Bruce
www.Glasair.org
mprather(at)spro.net Guest
Posted: Sun Nov 11, 2007 7:06 am Post subject: Magneto and VM1000 Dimming |
I went through that too, Dean..
If you measure the resistance between the p-connection on the mag and
the mag case, you are either measuring the resistance through the
primary winding of the coil in the mag, or through the breaker points in
the mag (depending on where mag/engine are positioned - making the
points open or closed). In either case, it's a low resistance value.
Normal behavior.
Matt-
DEAN PSIROPOULOS wrote:
the same results?
Dean
RV-6A N197DM
Posted: Mon Nov 12, 2007 5:04 am Post subject: Magneto and VM1000 Dimming |
My VM1000 would dim with my B&C dimmer....then I started having problems with the backlight not working at all. JPI told me there was something wrong with my wiring - checked that. I haven't flown yet but they wouldn't repair it - and wanted too much money for me to give JPI. I bought an Advanced Flight Systems AF3400EM - used most of the existing wiring and am a happy camper now.
Parting out my VM1000 to keep others going.....
