pwmac(at)sisna.com Guest
Posted: Sun Nov 11, 2007 8:26 pm Post subject: Satellite antenna ground planes required? |
Both will work fine looking thru fiberglass Just figure out a mount
under side. Best way to prove it is to do it. That was my method.
Paul
At 07:11 PM 11/11/2007, you wrote:
I have 2 (two) satellite antennas mounted to the top of my RV-10
cabin. On is for a WAAS GPS sensor and the Other is for an XM
weather receiver.The cabin top is entirely made of fiberglass/epoxy
composite. I've looked in vain for information as to whether or not
groundplanes are required for these antennas, and if so what
size/dimension. I would dearly appreciate any guidance and direction
the list or it's Sponsor might provide.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
nuckolls.bob(at)cox.net Guest
Posted: Mon Nov 12, 2007 6:10 am Post subject: Satellite antenna ground planes required? |
At 08:11 PM 11/11/2007 -0700, you wrote:
I have 2 (two) satellite antennas mounted to the top of my RV-10 cabin. On
is for a WAAS GPS sensor and the Other is for an XM weather receiver.The
cabin top is entirely made of fiberglass/epoxy composite. I've looked in
vain for information as to whether or not groundplanes are required for
these antennas, and if so what size/dimension. I would dearly appreciate
any guidance and direction the list or it's Sponsor might provide.
Ground planes at 1.5 GHz are not terribly
large in terms of real estate . . . and depending
on the antenna's design, may not be necessary
at all.
What ever manner of shelf, fabricated from aluminum
sheet and used to position the antennas at the
top of the fuselage will no doubt prove to be
adequate.
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
