		jackandval
  Joined: 18 Jul 2007 Posts: 21 Location: blairsville, GA
				 Posted: Sat Nov 17, 2007 6:03 pm    Post subject: Rectifier-Regulator |
				I have a Rotax 912 and it is overcharging. I can't find anything in the manuals of how to check if it is a bad regulator. If it is charging does that mean it is a bad regulator?
 Jack
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gilles.Thesee(at)ac-greno Guest
				 Posted: Sat Nov 17, 2007 6:21 pm    Post subject: Rectifier-Regulator |
				jackandval a écrit :
 Jack,
 We'll need some additional info.
 What voltage do you read, where and when ?
 What is the corresponding engine RPM ?
 How does the number of devices connected to the ship's circuit affect
 the readings ?
 What is the state of your battery ?
 How does actual charge influence the voltage readings ?
 Do you have the requested capacitor installed ?
 Have you checked every connection and wire, especially regulator ground ?
 Etc.
 Also, a schematic of your wiring will help interpreting the symptoms. It
 often boils down to bad wiring.
 Best regards,
 Gilles
 http://contrails.free.fr
		jackandval
				 Posted: Sun Nov 18, 2007 5:25 am    Post subject: Re: Rectifier-Regulator |
				In cruise (at)5200 RPM the voltmeter indicates about 13.5 to 14.0.
 If I load the system down, lights, radio,and strobes the amp meter will go from 20 amps to about 10 amps.
 Yes the capacitor is correct. No loose connections and good ground.
 Battery after flight was checked a few hours later and reads 11.8 or 9
 which sort of makes the battery suspect?
 But my question was  how do you test the regulator??????
 Jack
		pwmac(at)sisna.com Guest
				 Posted: Sun Nov 18, 2007 6:33 am    Post subject: Rectifier-Regulator |
				You do NOT have a regulator issue. You do might have a bad battery
 since the voltage is so low.
 IMO, cover up the  amp meter and pay attention to the voltmeter. If
 the voltage stays as you indicated all is well with the alternator
 and regulator.
 After flight a good battery should read above ~12.7+ and as high as
 13.5+ Of course if you are exceeding the alternator capability then
 the battery would not be fully charged. and could account for low
 batt voltage. Do the following on your next flight: Operate with the
 lowest electrical load you can and then check the batt volts an hour
 after flight then again in 24 hours. If the batt stays above ~12.7,
 then the batt is ok and you are just overloading he wimpy Rotax
 alternator. You could also verify the batt is good with an overnight
 charge at the 2 amp rate then wait 24 hours for it to loose its
 surface charge then see what the voltage is.
 Paul
 At 05:25 AM 11/18/2007, you wrote:
 Jack
 http://forums.matronics.com/viewtopic.php?p=146838#146838
		Float Flyr
				 Posted: Sun Nov 18, 2007 8:53 am    Post subject: Rectifier-Regulator |
				The test for the regulator is to use a voltmeter...  You're past that stage.
 The generator has to put out a voltage above that of the battery,
 theoretically 12 V. to allow the battery enough EMF to charge.  Most
 regulators are set to 13.8V., rounded off that's 14V which is what the
 certified planes rate their busses.
 Sounds to me like your regulator/rectifier is doing just fine.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		jackandval
				 Posted: Sun Nov 18, 2007 2:54 pm    Post subject: Re: Rectifier-Regulator |
				Thanks Guys! I think your right that it is the battery. I am charging the battery and will  see what it reads tomorrow.
 Jack
