Lanny Fetterman
Joined: 10 Jan 2006 Posts: 37 Location: Catawissa Pa.
Posted: Sun Nov 18, 2007 4:19 am Post subject: Drilling Lexan |
When I constructed my doors, I drilled the Lexan and aluminum tubing with a
regular 1/8 inch drill bit and used clecos as I went. After everything was
fitted I redrilled the Lexan holes to 9/64. I used aluminum rivets to
finish the project. After a few years I did develop one small crack about a
half inch long at one of the rivets. When I went Experimental, I was able
to cover the crack with the Experimental sticker.
Lanny N598LF FSII (fully inclosed)
_________________ Lanny Fetterman Firestar II N598LF |
