shoskins(at)MCHSI.COM Guest
Posted: Thu Nov 15, 2007 3:41 pm Post subject: Wherefore loadmeters? |
Does anyone know where Bob's articles on load meters are? I thought it might be in Chapter 7, but I couldn't find it.
Sam
nuckolls.bob(at)cox.net Guest
Posted: Fri Nov 16, 2007 6:15 am Post subject: Wherefore loadmeters? |
At 05:39 PM 11/15/2007 -0600, you wrote:
| Quote: | Does anyone know where Bob's articles on load meters are? I thought it
Sam
There are no articles specific to the topic
of loadmeters. In general, these are generic
ammeters but instead of calibrating the scale
plate in amperes, they are calibrated in percent
with 100% being full scale. See:
http://www.aeroelectric.com/Pictures/Instruments/Loadmeter_2.jpg
http://www.aeroelectric.com/Pictures/Instruments/loadmeter.jpg
https://matronics.com/aeroelectric/Catalog/9007-120-1_Loadmeter.jpg
The handy thing about this calibrating convention
is that a single instrument can be used with
any size alternator or generator. The full
scale sensitivity of instrument in amperes is
set by the size of the companion shunt. See:
http://www.aeroelectric.com/Pictures/Instruments/20-50_Shunt.jpg
A 20A shunt goes with alternators like the SD-20
and the instrument reads full scale when 100%
of the 20A machine is being taxed. It follows that
other sized alternators are monitored with the
appropriately sized shunt on the same instrument.
When the system is fitted with more than one
alternator, a single instrument can be switched
between the two sources, each fitted with the
appropriate sized shunt; wired as described here:
https://matronics.com/aeroelectric/Catalog/AEC/9007/AEC9007-700.pdf
( -Thomas Paine 1776- )
Posted: Fri Nov 16, 2007 6:54 pm Post subject: Wherefore loadmeters? |
Thanks for clearing that up for me.
Sam
On Nov 16, 2007 7:53 AM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
Sam Hoskins
www.MistakeProofing.Net
www.MistakeProofing.net/blog/
618-967-0016 ph.
312-212-4086 fax [quote][b]
Posted: Sat Nov 17, 2007 4:25 am Post subject: Wherefore loadmeters? |
Another question about load meters.
Most ammeters display +/- amps; charge/discharge.
Why do load meters not display +/- percent?
Should a panel contain both a load meter and an ammeter, or can we get away with strictly a load meter?
Thanks.
Sam
Sam Hoskins
618-967-0016 ph.
Bob McC
Posted: Sat Nov 17, 2007 6:22 am Post subject: Wherefore loadmeters? |
_________________ Bob McC
Falco #908
(just starting) |
kesleyelectric(at)chooseb Guest
Posted: Sat Nov 17, 2007 7:15 am Post subject: Wherefore loadmeters? |
Sam,
The conventional battery ammeter measures current going into the battery under charging conditions (+ reading), or flowing out of the battery (- reading) when the alternator is not supporting the load. When the alternator is supporting the load and the battery is fully charged, the ammeter will show very little deflection.
The load meter measures only alternator output,regardless of whether that output is supporting the load or charging the battery.
Tom Barter
Kesley, IA
Avid Magnum
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins
Sent: Saturday, November 17, 2007 6:22 AM
Subject: Re: AeroElectric-List: Wherefore loadmeters?
Thanks.
Sam
Sam Hoskins
618-967-0016 ph.
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sun Nov 18, 2007 8:12 am Post subject: Re: Wherefore loadmeters? |
Whyfor Loadmeters? Am I missing something?
I suggest that unless you can find a really great reason for having a loadmeter. Don't bother.
My airplane will not have one. One the other hand what my airplane does have (sleeping in a large box full of stuff....) is a Xantrex XBM battery monitor. This puppy monitors the health of the battery and tells me how long the battery will power the airplane at the current load and lots more. MUCH better information.
See: http://www.xantrex.com/support/web/id/1006/support1.asp
and http://www.xantrex.com/web/id/96/p/1/pt/7/product.asp
"What the West really has to offer is honesty. Somehow, in the midst of their horrid history, the best among the Gaijin learned a wonderful lesson. They learned to distrust themselves, to doubt even what they were taught to believe or what their egos make them yearn to see. To know that even truth must be scrutinized, it was a great discovery...."
-- David Brin, "Dr. Pak's Preschool
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
jan.de.jong(at)xs4all.nl Guest
