planesmith(at)hotmail.com Guest
Posted: Sun Nov 18, 2007 10:51 am Post subject: Regulator Options for ALX8521 |
I have a Electro-Systems (Prestolite) ALX8521 70 amp 12 volt alternator I would like to use on my RV project. What are the options for a regulator? VR166 (generic Ford) with OV protection, B&C, or what? I've gone through the AeroElectric book and the archives but haven't found a definitive answer, maybe the answer is too obvious. Any insights will be helpful.
Vern Smith
You keep typing, we keep giving. Download Messenger/im/home/?source=CRM_WL_joinnow' target='_new'>Join in! [quote][b]
rjquillin
Posted: Sun Nov 18, 2007 11:33 am Post subject: Regulator Options for ALX8521 |
At 10:48 11/18/2007, you wrote:
| Quote: | I have a Electro-Systems (Prestolite) ALX8521 70 amp 12 volt
Vern Smith
Might want to look at some of the offerings here:
http://zeftronics.com/
R15V00RevA is about the same as B&C LR3C-14 for less $$$.
nuckolls.bob(at)cox.net Guest
Posted: Sun Nov 18, 2007 8:26 pm Post subject: Regulator Options for ALX8521 |
At 11:48 AM 11/18/2007 -0700, you wrote:
| Quote: | I have a Electro-Systems (Prestolite) ALX8521 70 amp 12 volt alternator I
Your options are varied and numerous. You can
go the generic route and assemble regulator, ov
protection and lv warning from individual components
or go the Cadillac rout with the B&C LR3 series
controllers with everything in one package. There
is no one choice inherently superior to others
beyond avoiding products with demonstrably poor
service lives (i.e. poor return on investment).
( -Thomas Paine 1776- )
Posted: Mon Nov 19, 2007 7:39 am Post subject: Regulator Options for ALX8521 |
Because of the 70 amp rating I didn't realize my options were so wide open.
Thanks for the replies,
Vern Smith
> Date: Sun, 18 Nov 2007 22:24:16 -0600
| Quote: | To: aeroelectric-list(at)matronics.com
Subject: Re: AeroElectric-List: Regulator Options for ALX8521
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
>Thanks,
You keep typing, we keep giving. Download Messenger and join the i’m Initiative now. Join in! [quote][b]
Posted: Mon Nov 19, 2007 9:00 am Post subject: Regulator Options for ALX8521 |
At 08:38 AM 11/19/2007 -0700, you wrote:
| Quote: | Because of the 70 amp rating I didn't realize my options were so wide open.
Vern Smith
Unlike generators . . . the regulator is NOT affected
by the size of the alternator. I've installed the LR3
series regulators on alternators from 35 to 105 amps
with good results.
A generator's regulator MUST be aware of the generator's
loads for the purpose of adjusting output to LIMIT the
output current and prevent burned wires, commutator
and brushes. Before the advent of solid state
rectifiers, a generator's regulator needed three
separate "relay" looking devices for the purpose
of controlling voltage, limiting current and electrical
disconnection of a generator that is turning too slow
or stopped. An exemplar regulator looked like this:
http://www.aeroelectric.com/Pictures/Regulators/GenReg_2A.jpg
Alternators are inherently current limited so
don't need attention from the regulator for
protection. They are inherently incapable of
reverse current flow through the rectifiers
that converts the alternator's AC to system DC
current. This leaves only the voltage regulator
function which was handled with a simpler device
http://www.aeroelectric.com/Pictures/Regulators/ALTREG2.jpg
where the right-hand critter is the votlage
regulator. The one on the left is a field
control relay which is surplus to management
of the alternator in most systems. A solid
state version without a field control relay
looks more like this:
http://www.aeroelectric.com/Pictures/Regulators/Ford_SS_Reg_open.jpg
and will work just fine with about any externally
regulated alternator.
Posted: Mon Nov 19, 2007 11:59 am Post subject: Regulator Options for ALX8521 |
Thanks for the explanation and expanding my knowledge base.
Vern
> Date: Mon, 19 Nov 2007 10:56:01 -0600
Subject: RE: AeroElectric-List: Regulator Options for ALX8521
>Vern Smith
with good results.
Share life as it happens with the new Windows Live. Share now! [quote][b]
