bhcishere(at)ca.rr.com Guest
Posted: Sun Nov 25, 2007 7:14 pm Post subject: Comm Radio Problem |
Need help from the RF guru's,
I have been trying to resolve a problem with a friend's comm radio for some time now with no success.
Transmit is never a problem and reception is good most of the time. The problem is local to some areas, frequencies and direction of flight.
Specific example: Depart CNO talking to SoCal on 125.5, all is well when flying westbound. On return leg (eastbound) to CNO, unable to receive SoCal but the controller receives me perfect (this is evident by other aircraft relaying messages from the controller and the fact that once I can hear the controller he is not very happy). It does not appear to be an issue with SoCal as I can hear them when flying eastbound with an Icom handheld.
This same problem occurs in other areas also but is very prominent in the example given.
The same problem remains after multiple changes: KX-170B, Garmin SL-30, Stainless antenna, two different fiberglass whip antenna's and have tried both top and bottom mounting. The only thing that has not (yet) changed is the coax which is currently RG-58.
I am at whit's end, any help or suggestions would be appreciated.
Bryan
rnewman(at)tcwtech.com Guest
Posted: Mon Nov 26, 2007 4:53 am Post subject: Comm Radio Problem |
Bryan, I did battle with my Garmin 530 communications radio for months in my Glastar after an instrument panel re-do. It had been great for 7 years, after the panel overhaul. I had similar communications problems. At various times it worked great, other times not at all. Ultimately I found a bad coax connection. The shield of the coax was not making connection with connector at the radio end. It was one of those coax connectors that uses a set-screw to connect the shield to the connector body. It was not a crimp on style. I changed the connector to a crimp on type and the problem has been solved. We tried everything under the sun, including getting a loaner 530 from Garmin, but the smoking gun was in the connector.
Bob Newman
www.tcwtech.com
nuckolls.bob(at)cox.net Guest
Posted: Mon Nov 26, 2007 7:01 am Post subject: Comm Radio Problem |
handheld.
example given.
Bob Newman has made an excellent suggestion that
I can only echo. If your radio bench-checks okay,
then something is amiss in the installation and the
MOST likely culprit will be the antenna system. Since
you can't do much to hose up a piece of steel
once crafted into an antenna, this leaves the coax
and connectors.
See if you can get an SWR bridge to check your
antenna's electrical performance and go over
the connectors with a fine toothed comb.
( -Thomas Paine 1776- )
