reinkings(at)comcast.net Guest
Posted: Wed Dec 05, 2007 8:50 am Post subject: Removing metal scratches on Rudder |
Just finished riveting the rudder together. Being a newbie builder,
even being careful, have all kinds of very thin scratches on the skin
surfaces. Is this deadly? Is there some way to buff them out and
(lastly) quick instructions on how to do that?
Thanks, gang, John Reinking (starting 601XL)
ifly4fun2(at)sbcglobal.ne Guest
Posted: Wed Dec 05, 2007 10:36 am Post subject: Removing metal scratches on Rudder |
John,
I would say its not deadly but some attention may be necessary. Can you catch the scratch with a
fingernail? If so it is probably worth taking out. I had some rather deep scratches perpendicular
to the aluminum grain on my rudder spar and I used 400grit alum oxide paper to get them out.
Since it was is the spar I went with the grain also. If they aree minor scratches you may get
them out with some (MAROON 7447 3M Scotchbrite Pads). Whatever you choose to use make sure it is
not iron (ferrous) based material. Silicon or Aluminum Oxide is the choice of content.
Art
John,
Art
shilcom
Posted: Wed Dec 05, 2007 11:45 am Post subject: Removing metal scratches on Rudder |
If you are going to paint, then wait till painting time. If you can feel the scratch with your fingernail, then work on it with red scotchbrite pad and if that doesn't do it start with 250 grit emry paper and get courser as needed. I but scotch brite will get it out. bob U.
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Wed Dec 05, 2007 4:56 pm Post subject: Re: Removing metal scratches on Rudder |
Sorry for sticking my nose in your post reinkings(at)comcast.net, but what if your buffing most of the skin, instead of painting?
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
zodierocket(at)hsfx.ca Guest
Posted: Wed Dec 05, 2007 6:30 pm Post subject: Removing metal scratches on Rudder |
If your nail is stuck in it then mild buffing is in order, but since it
is on the skin I would not worry too much, the properties of 6061 will
allow it to stay resistant to corrosion. If you are buffing your plane
then it will come out. If your painting then a small amount of putty
will remove all trace. Once again this is for a skin in which we have a
scratch that we are not worried about becoming a crack. If this was a
spar then all trace would need to be removed.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
kmccune
Posted: Wed Dec 05, 2007 7:19 pm Post subject: Re: Removing metal scratches on Rudder |
Thanks Mark,
I was thinking it was more of a problem then that.
Kevin
Dorothy McCune |
Posted: Thu Dec 06, 2007 12:14 am Post subject: Removing metal scratches on Rudder |
Thanks for your ideas gentlemen. We are considering a polished metal
but have not ruled out painting. I do realize that scratches
sufficient to be easily felt or if on a location that cannot tolerate it
(and must be replaced) but wasn't sure about these soft surface
scratches. John/Woodinville, WA
shilcom
Posted: Thu Dec 06, 2007 6:44 am Post subject: Removing metal scratches on Rudder |
If your buffing or polishing you've got a lot of work ahead of you. The basic premise is that you will have to sand, using course enough paper to remove and feather out the scratch, then begin to sand and polish using successively finer paper and polishing compound untill you get back to the polish desired. I've done it many times, mostly on plexiglass, but also on aluminum and have the kits to do it. Bob U.
Posted: Fri Dec 14, 2007 9:33 pm Post subject: Removing metal scratches on Rudder |
I would caution that some areas of skin are more subject to the effects of sonic fatigue than others. The input stimulations can be proprllor pulses, engine exhaust reports, high frequency air buffeting, and anyplace that goes resonant as a result of applied sonic pressures. These possible locations need to have any "sharp bottomed" scratch burnished out (then filled, if desired).
ZodieRocket <zodierocket(at)hsfx.ca> wrote:[quote] --> Zenith-List message posted by: "ZodieRocket"
