Posted: Fri Dec 14, 2007 4:15 pm Post subject: Main Spar Bolts and Holes |
OK builders here is one for you....
I m about to install my wings on the 601 XL QBK.
The other night I wanted to see how tight the main spar bolts would fit into the wing spar ( factory drilled ) holes.
Man O man, there is a lot of "slop" in the holes.
I emailed Zenith and told them that I was concerned about this critical part.
The first answer I got from Zenith was, " Some slop is needed to get the bolts in the holes "....
I disagreed..
Zenith asked me to measure the holes. I did. Used a caliper on the bolts and then the holes. I got a reading of .011..
Eleven thousandths.....difference.
I m not a machinist but I aint totally stupit either.
Then Zenith emailed and said that I need to increase the spar hole size to an AN-6. Thats 3/8 inch.....
Since I m not into dying just yet I asked Zenith engineers to confirm the the AN 6 size is safe. I am worried about the metal removal on the spar.
They did....Said that in no way will going to an AN 6 decrease the wing strength.....
Sooooo, what I want to know from you builders is this: Tell us about your experience with the spar and bolts. Were yours tight ??? Sloppy ??
Steve W
Posted: Fri Dec 14, 2007 4:28 pm Post subject: Main Spar Bolts and Holes |
When you enlarge the holes use an undersized drill and then a reamer.
-- Craig
bryanmmartin
Posted: Fri Dec 14, 2007 4:35 pm Post subject: Main Spar Bolts and Holes |
My spar bolts fit very snug, no slop at all.
I disagreed..
Steve W
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
papaniapatrick(at)aol.com Guest
Posted: Fri Dec 14, 2007 4:51 pm Post subject: Main Spar Bolts and Holes |
I am building an XL, but it is not a quick build. My wing spar bolts are a tight fit into the holes. I fitted pins for the wing spars so that I could trial fit the wings during construction and fitting. There was absolutely no slop what so ever.
lwinger
Posted: Fri Dec 14, 2007 5:09 pm Post subject: Main Spar Bolts and Holes |
I scratch built my spars and worked for many, many hours to insure that there was no slop in the bolt/bolt hole interface. If I had known it was allowed, I could have relaxed more (insert goofy looking smiley face here).
Larry Winger
601XL/Corvair
Tustin, CA
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Posted: Fri Dec 14, 2007 5:27 pm Post subject: Main Spar Bolts and Holes |
Larry, it may be allowed but I m not pleased with slop.
Not sure but rumor has it that a 601 lost a wing. Anyone know if thats true ? So thats why I m not happy with loose bolts.
SW
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Fri Dec 14, 2007 5:39 pm Post subject: Main Spar Bolts and Holes |
mine were tight-----------------
George May
601XL 912s
Get the power of Windows + Web with the new Windows Live. Get it now!
Posted: Fri Dec 14, 2007 6:04 pm Post subject: Main Spar Bolts and Holes |
I was a quick built Kit and my spar bolt holes were missaligned and tighter. The problem lies in the fact that the spar cassette can slide down when the wings are off. so took oversized screw driver and as wings were placed, I hammered the driver through to realign the bolt holes. A few were tight and we bought the AN 6 size bolts and instead tried to hammer the suppled bolts. That finally worked. AN 6 would work, thicker bolt afterall than an5s. The wings you mentioned fell off the plane because the flyer forgot that manauvering speed was 103, not 130. 6 gs is "utility at manauvering speed. Irrelevant to whether AN6 bolt. When the bolts are bolted in Torgue them to proper speck, AN6 have different Torques. Toirque the rear spar bolt as well. As per Faa documents, "if bolts are torqued per the chart, the default rate is zero".
JAPhillipsGA(at)aol.com Guest
Posted: Fri Dec 14, 2007 6:21 pm Post subject: Main Spar Bolts and Holes |
Steve, my bolts were a good fit. On enlarging the holes and bolts. Do NOT drill to the final size. Buy and use a reemer. Large drill bits make three sided holes. Also on the bolts. If your going to the expense buy NAS bolts. They are much stronger than ANs and closer tolerance. At my next annual I plan on replacing my XL AN spar bolts with NAS bolts. Best of luck, Bill of Georgia
See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) [quote][b]
sky_ranger161
Posted: Fri Dec 14, 2007 8:05 pm Post subject: Main Spar Bolts and Holes |
Hey guys,
Like Larry, I scratch-built my spars and spent an insane amount of time lining up, drilling, and reaming the spar bolt holes. Mine are what Section 7-39 of the AC43.13-1B says bolt holes of primary connecting elements should be - a "light-drive" fit.
Since I know the next question, a "light-drive" fit is defined as "an interference of 0.0006 inch for a 5/8 inch bolt." For those of us (me included) that need further explanation, that's tight.
God knows I'm no expert. Just passing along what the book says.
Debo Cox
Nags Head, NC
Scratch-built XL/Corvair
www.mykitlog.com/debo
jeffrey_davidson(at)earth Guest
Posted: Fri Dec 14, 2007 8:35 pm Post subject: Main Spar Bolts and Holes |
Steve,
I'm building an HD, but I can tell you that the holes in the splice plate that connects the center wing spar with the outer wing spar are 3/8 and 5/16. I had to replace the rear splice plates from the factory so I drilled those holes. With a drill and then a reamer in a drill press, I got a snug fit that required just a little pressure to get the bolts into the holes through the splice plates and spar caps. They were a tight enough fit that they would not go through unless the plate was exactly flat and lined up with the spar caps. The point is that 3/8 size is normal in the HD/HDS wing spar caps.
Jeff Davidson
<snip>
Steve W
[quote] [b]
Ron Lendon
Afterfxllc(at)aol.com Guest
Posted: Sat Dec 15, 2007 12:16 am Post subject: Main Spar Bolts and Holes |
Since the center section and main spars are supposed to be match drilled is the slop the same in the wing spars also? I have helped build 3 601's and all of the spar bolts were tight but not so tight that if they were aligned perfectly that you couldn't slide them in with your hand. If you line them up correctly you shouldn't have to knock them in. It is also a good idea to sacrifice a couple of bolts and grind them to a point and remove all threads then polish them so you can more easily locate the holes.
But the bigger question is where is Zeniths quality control?????
In a message dated 12/14/2007 7:16:49 P.M. Eastern Standard Time, notsew_evets(at)frontiernet.net writes:
I disagreed..
Steve W
Quote: |
://www.matronics.com/contribution">http://www.matronics.com/contribution
f="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
.matronics.com/">http://forums.matronics.com
See AOL's top rated recipes and easy ways to stay in shape for winter.
daveaustin2(at)primus.ca Guest
Posted: Sat Dec 15, 2007 7:25 am Post subject: Main Spar Bolts and Holes |
One additional suggestion.. whether they are tight or not, have someone preload the wing upward, just by lifting the tip by a few pounds, before and as you tighten the bolts.
Dave Austin 601HDS - 912, Spitfire Mk VIII
Posted: Sat Dec 15, 2007 7:47 am Post subject: Main Spar Bolts and Holes |
This "slop" that I found is in the wing spars AND the carry through spar in the fuselage. All holes are "sloppy"...
I ve been building and maintaining aircraft for 43 years now and this is the first I ve seen this. Thats why I questioned Zenith in the first place. Sounds like its an easy fix using a 3/8 reamer but I agree "where is Zeniths quality control". I removed these quick built wings from the factory crate and know that the problem happened at Zenith.
The difference from AN 5 to AN 6 dosent seem like a big deal but I think it is. Hold up a 5/16 bolt next to a 3/8 and tell me it isnt.
Again, I really thank you guys for the feed back.
No one has said a bad thing against using the AN 6 bolt.
It will be a pain the purchase a reamer and go in the fuselage to correct the problem.
Steve W
lwinger
Posted: Sat Dec 15, 2007 11:53 am Post subject: Main Spar Bolts and Holes |
Steve, this may go without saying but you'll really want to lock the whole assembly together as rigidly as possible before reaming anything.
I would start by filling all but one hole with the AN 5 bolts. Once they are all in place, if there is still movement between the center and wing spar,
I would find a way to carefully clamp them together. Then I would remove one bolt at a time, ream that hole, and replace with the AN 6 bolt before
proceeding to the next. That way you don't magnify the effect of the slop, just making it bigger slop.
On the bright side, assuming there is no degredation of structural integrity by enlarging the holes in the web/doublers, you'll have even stronger bolts
than the rest of us. Think of it as a blessing in disguise!
Larry Winger
601XL/Corvair
Tustin, CA
Tustin, CA
planecrazydld(at)yahoo.co Guest
Posted: Sat Dec 15, 2007 12:11 pm Post subject: Main Spar Bolts and Holes |
While there may be no issue with going out to 0.375"ø for the holes, maybe use an NAS oversize standard bolt and match ream to fit?
The larger 0.375" holes will have better bearing strength due to the larger diameter - all things considered.
steve <notsew_evets(at)frontiernet.net> wrote:[quote] OK builders here is one for you....
I disagreed..
Since I m not Find them fast with Yahoo! Search. [quote][b]
Posted: Sat Dec 15, 2007 2:42 pm Post subject: Main Spar Bolts and Holes |
If there is enough slop that the wings can move up and down with the bolts in place I would tell zenith to send me a new set of wings and center section if you drills them and mess them up they are yours. If you hold Zenith to the fire on this one they will get to the problem and make sure it doesn't happen again but if you fix it they will figure out of sight out of mind. And worse if you mess it up you own a set of wings that they will say "Prove they were wrong in the first place" You should have been shipped the proper parts in the first place.
In a message dated 12/15/2007 2:54:47 P.M. Eastern Standard Time, larrywinger(at)gmail.com writes:
Quote: | Steve, this may go without saying but you'll really want to lock the whole assembly together as rigidly as possible before reaming anything.
Larry Winger
601XL/Corvair
Tustin, CA
