Ed Anderson
Posted: Fri Dec 21, 2007 5:47 am Post subject: Brake lines and Hydrauli fire |
After a ruptured aluminum brake line (after 340 hours of flying) resulted in runway departure, a hydraulic fire which charred tire and wheel pant - whicht fortunately did not damage the aircraft, I went with stainless steel braided brake lines with Teflon liners
I also replace the older brake fluid with the newer MIL-PRF-83282 D brake fluid which has a much higher flash point (around 440F). I then replace the brake rotors with discs twice the thickness to hold down the temps.
Believe me it is a helpless feeling to have your brake go to the floor and find you have no effective directional control. Just had time to get the engine shut down and used the starter to get the prop horizontal before going into a ditch off the side of the runway. Perhaps I should have considered ground looping - with the remaining good brake, but the thought did not occur until afterwards.
Did I mention, its smart to carry a fire extinguisher in your cockpit?
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)
http://www.andersonee.com
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.dmack.net/mazda/index.html
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
Posted: Fri Dec 21, 2007 6:21 pm Post subject: Brake lines and Hydrauli fire |
Ed Anderson wrote:
| Quote: | DIV { MARGIN: 0px } After a ruptured aluminum brake line (after 340 hours of flying) resulted in runway departure, a hydraulic fire which charred tire and wheel pant - whicht fortunately did not damage the aircraft, I went with stainless steel braided brake lines with Teflon liners
| Sorry ED. I'm not picking on you!!! Honest!!!
Whgere did the hard line break??? At the flare??? Not uncommon. Happened to me. My fault. Using cheap flaring tool (but an AN flare, not a plumbers flare). Also. clamping the tubing down next to the caliper hinders it's natural movement as the brake pads wear. another problem area. Unfortunately, I was aware of the problem (yeah, after I lost a brake on my Pitts but no fire or other damage besides extreme embarrassment cause by doing pirouettes on the runway) | Quote: | I also replace the older brake fluid with the newer MIL-PRF-83282 D brake fluid which has a much higher flash point (around 440F). I then replace the brake rotors with discs twice the thickness to hold down the temps.
| Thanks for those two tips. I wasn't aware of either. Can you give us a part number for the thicker rotors??? | Quote: | Believe me it is a helpless feeling to have your brake go to the floor and find you have no effective directional control.
| AMEN!
| Quote: | Just had time to get the engine shut down and used the starter to get the prop horizontal before going into a ditch off the side of the runway. Perhaps I should have considered ground looping - with the remaining good brake, but the thought did not occur until afterwards.
| Hmmm. For me, I was mashing both pedals for all I was worth ..... and it came as a surprise to me that the right one was hitting the firewall! | Quote: |
| Ya know, I'm rather thick headed (and oblivious to strong hints) ...... but even after two fires up front .... still don't have one. Both fires were due to my stupidity (hope I don't make more mistakes like that) and on the ground. Educational experiences I call 'em.
Linn
again, do not archive.
Ed
Ed Anderson
Matthews, NC
Vanremog(at)aol.com Guest
Posted: Fri Dec 21, 2007 7:12 pm Post subject: Brake lines and Hydrauli fire |
In a message dated 12/21/2007 6:22:21 P.M. Pacific Standard Time, pitts_pilot(at)bellsouth.net writes:
| Quote: | | Quote: | replace the older brake fluid with the newer MIL-PRF-83282 D brake fluid which has a much higher flash point (around 440F). I then replace the brake rotors with discs twice the thickness to hold down the temps.
| Thanks for those two tips. I wasn't aware of either. |
Search on the MIL-PRF in the archives. I tried to hip everyone to this a couple of years back when I did the research and changed mine.
I believe that several manufacturers have recommended this change for their fleets but suspect that the old MIL-H-5606 is just too deeply ingrained in the FBOs for anyone to stock to the better fluid.
BTW, can the thicker Cleveland disc really fit under the old (original non pressure recovery) wheel pants?
N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley)
See AOL's top rated recipes and easy ways to stay in shape for winter.
Posted: Sat Dec 22, 2007 4:33 am Post subject: Brake lines and Hydrauli fire |
Hi Again, Ed!
Wow- quick thinking. Sometimes the force is with you. I was going to go
the Teflon route for the brake line loop to the caliper, but it's been
suggested that there is a threat of brake temps melting the Teflon in the
braided line. Does anyone have any hard evidence, numbers, or anecdotal
info to this effect?
| Quote: | Did I mention, its smart to carry a fire extinguisher in your cockpit?
Thanks for reminding me to get that on the do list.
glen matejcek
aerobubba(at)earthlink.net
Ed Anderson
Posted: Sat Dec 22, 2007 6:58 am Post subject: Brake lines and Hydrauli fire |
Hi Linn,
Actually, I was surprised at the location of the break in the line, myself. I would have though the flare would be the most likely place. All flares were made with aircraft quality 37deg flaring tools.
But, in my case, a chunk of the line blew out, about 1/2 the circumference of the tube and about 1" long - simply blew the side wall out of the tube back about 3" from the Flare. I'll try to post some photos in the photo section of the list.
I suspect that I may have work harden the tube in that area by trying to get the loop around the axis correct - or it could have possibly been nicked or otherwise damaged. However, after thinking about it, I decided that having a length of aluminum tubing which does not have the best fatigue life designed to flex as the calipers moved in and out was not the best approach. Yes, I know, hundreds of folks have used it with no problem - that not withstanding, aluminum tubing fatigues fairly easily and I decided to eliminate it in my brake lines.
The Cleveland part number for the thicker rotors is 164-09900. I purchased an equivalent pair from Chief Aircraft made by RAPPCO part number RA164-09900. Aircraft Spruce sells the complete 199-93 kit which when I checked will cost you around $300 for basically 2 rotor discs, some shims, the brake linings and some labels to put on your wheels.upgrade kit.
I purchased the two rotors from chief for $140 for the pair. Be advised you will need a 1/8" spacer to fit between the two caliper pieces to accommodate the thicker disc - Cleveland wanted $85 EACH for a 1/8" thick piece of aluminum with two holes drilled in it - the spacer. I made mine out of 6061T6 aluminum I had laying around. Took me about 45 minutes as you need to shape the inner side of the spacer so it matches the curve of the disc.
Everything will fit inside the old (pre-pressure recovery) wheel pants, but you will probably need to remake your wheel pant bracket - I made new ones out of SS sheet - the old ones might work, but you have to space it out further from the wheel due to the thicker rotor and then the wheelpant attachment screws hole may not line up with the bracket nutplates. You will need to make new bracket spacers and add 1/8" to the length of those aluminum tube spacers that stand the brackets off of the wheel.
The brakes feel much firmer, I get no brake fade even under heavy braking and I have not smelled any indication that the brakes are getting as hot as they once did. Theoretically having twice as much metal to absorb the heat, the temps should be lower.
Hope this helps
Ed
Matthews, NC
Ed Anderson
Posted: Sat Dec 22, 2007 7:03 am Post subject: Brake lines and Hydrauli fire |
Yes, I had to buy the new stuff by the gallon - enough to last me for a decade {:>). Have not found any at local FBOs who carry it. Apparently the need for the new higher flash point was driven my Military need for less flammable brake fluid - so I read.
Yes, the thicker rotors will fit under the old (pre-pressure recovery) wheelpants. However, I had to redo my wheelpant brackets and add 1/8" to the three aluminum tube bracket spacers.
Ed
Matthews, NC
Ed Anderson
Posted: Sat Dec 22, 2007 7:07 am Post subject: Brake lines and Hydrauli fire |
Hi Glen,
Well, I didn't think to try ground looping with the one good brake - it may
not have worked out too well with a nose wheel aircraft - I can just picture
it pitching over in a sharp turn. Perhaps the fact, I had just installed
a new $1500 propeller might have had some influence on the decision process
The brake lines with Teflon lining are standard use brake lines. I have
found that having stainless steel braid around any hose liner material seems
to do a good job of holding the temps down. Not to say it couldn't happen.
My view is the stainless steel Teflon lines are less likely to give you an
immediate and catastrophic failure - I believe that leaks would develop and
you would get some indication (mushy peddle?) of a problem before the leak
got large enough to preclude braking. But, that is just speculation on my
part.
Yes, get that fire extinguisher - that way you will never need it.
Ed
Matthews, NC
