aadamson(at)highrf.com Guest
Posted: Fri Feb 24, 2006 7:56 am Post subject: SD-20 Alt performance chart? |
Bob, did you ever put together one of these for the SD-20? B&C specify 20A
output at 3500rpm, so I would assume that you could use the same "ratios"
and determine that on a continental for example, that is a 1.15:1, that
you'd have full output at 2900ish rpm?
http://www.aeroelectric.com/Reference_Docs/Alternator_Data/SD8-Performance.p
df
nuckollsr(at)cox.net Guest
Posted: Fri Feb 24, 2006 9:06 am Post subject: SD-20 Alt performance chart? |
At 10:51 AM 2/24/2006 -0500, you wrote:
The SD-20 is an L-40 with different shoes. It's limited in output
only because of the reduced speed on the vacuum pump pad. It's
performance is described on B&C's website at:
http://bandc.biz/SD20REVC.pdf
Posted: Fri Feb 24, 2006 9:35 am Post subject: SD-20 Alt performance chart? |
Cuz the ignorance, but what ALT rpm would I expect to see on a continental
io-550 vacuum pad, when the engine is turning 2500 RPM?
Alan
BobsV35B(at)aol.com Guest
Posted: Fri Feb 24, 2006 12:48 pm Post subject: SD-20 Alt performance chart? |
In a message dated 2/24/2006 11:37:58 A.M. Central Standard Time,
aadamson(at)highrf.com writes:
Alan
7500
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
Posted: Fri Feb 24, 2006 1:34 pm Post subject: SD-20 Alt performance chart? |
Bob, does that make sense. 7500 would give almost 40amps out of the SD-20,
is a continental really 3:1 on the vacuum pad? Engine rpm 2500, vacuum pad
7500?
Alan
Posted: Fri Feb 24, 2006 8:32 pm Post subject: SD-20 Alt performance chart? |
Good Evening Alan,
I had my head up and locked when I responded. The regular alternator drive
on most 520 or 550 Continentals spins the alternator at three times crankshaft
speed. That is what I had in mind. The accessory drive that often runs the
vacuum pump will spin at one and a half times crankshaft speed on all six
cylinder Continentals.
Sorry, I goofed!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 2/24/2006 6:58:53 P.M. Central Standard Time,
<aadamson(at)highrf.com>
Bob, does that make sense. 7500 would give almost 40 amps out of the SD-20,
7500?
Alan
