lrm(at)skyhawg.com Guest
Posted: Wed Dec 26, 2007 8:38 am Post subject: Prop Bolt Patterns |
The bolt pattern for my new PRSU measures out to be 100mm with 6 3/8" bolts. That is supposed to be the large Rotax, right? Now I am confused because I called Powerfin about a new prop. They said "no it's a 4" or 101,6mm pattern". Well, I can read a caliber unless it's Miller time. I have four calipers, they all lie at times. So I argued with the guy. He almost convinced me my PRSU was drilled wrong. He wasn't that convincing because I didn't buy a prop, yet. I had an old spacer plate for an SAE-1. Just for fun, I put it in the end mill and drilled a 4" pattern in between the 4 3/8" pattern. Took it over to the PRSU and of course it was too big by about 1.6mm. I knew it would be, but seeing is believing, plus it was scrap anyway.
I am still confused, Culver says it a large 100mm Rotax. Powerfin says they would have to drill a special prop hub for me because the large Rotax is 4". Are there two large Rotax patterns? It wouldn't surprise me. Everybody knows more about this stuff than I do, so someone please straighten me out. Does anyone know where I can find a chart of all the different small bolt patterns for our type of engines?
Building cars was less confusing and a whole lot cheaper.
LRM, www.skyhawg.com
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Mainwheels
Posted: Wed Dec 26, 2007 10:18 am Post subject: Prop Bolt Patterns |
Hi;
The "old" 912s had the 100mm bolt circle. New 912s have a 4 inch or
101.6 dia bolt circle. The bolts are still 8 mm.
Mike
CH601HDS 1200+ hrs
UHS Spinners
LRM wrote:
Quote: | The bolt pattern for my new PRSU measures out to be 100mm with 6 3/8"
LRM, www.skyhawg.com <http://www.skyhawg.com>
Posted: Wed Dec 26, 2007 6:52 pm Post subject: Prop Bolt Patterns |
This PRSU has 12 holes. It appears that I have been measuring the same two
holes every time and I must have done it at least ten times. I happened
to measure again today and low and behold this set of holes was not the same
as the other ten sets. They were 4". What a deal. You sure can't tell
the difference just by looking. The old boy that built it was smarter than I
gave him credit for, he drilled for both sets. Since I didn't buy it
directly from the him, I didn't know. But I did wonder why he put 12 holes
in it. Take care, LRM.
