bearup(at)ida.net Guest
Posted: Tue Jan 08, 2008 7:37 pm Post subject: 701 Wings Wanted |
I recently purchased a Zenith 701 project plane that has some wing damage, and figured I should check with the list to see if anyone here has a good set of 701 wings for sale, or perhaps a wing kit?
Stan Bearup
American Falls, Idaho
(208) 226-5531
bearup(at)ida.net (bearup(at)ida.net)
john.marzulli(at)gmail.co Guest
Posted: Wed Jan 09, 2008 12:43 am Post subject: 701 Wings Wanted |
Zenith will happily sell you a wing kit, and that is probably the best way to go.
The wings will have to be built with a pickup template made from the fuselage in order for a proper fit to be obtained.
Good luck!
DO NOT ARCHIVE
On Jan 8, 2008 1:42 PM, Stan Bearup <bearup(at)ida.net (bearup(at)ida.net)> wrote:
| Quote: | I recently purchased a Zenith 701 project plane that has some wing damage, and figured I should check with the list to see if anyone here has a good set of 701 wings for sale, or perhaps a wing kit?
Stan Bearup
(208) 226-5531
John Marzulli
http://701Builder.blogspot.com/
"Flying a plane is no different than riding a bicycle... it's just a lot harder to put baseball cards in the spokes.
-Airplane The Movie [quote][b]
skyguynca
Posted: Wed Jan 09, 2008 2:42 am Post subject: 701 Wings Wanted |
Becareful Stan, if someone does offer to sell you a set of wings then he will get FLAMED!!!! on here and accused of selling illegal copyrighted parts, even though they are only trying to help you.
David Mikesell
230 Theresa Drive, #6
Cloverdale, CA 95425
209-224-4485
skyguynca(at)skyguynca.com (skyguynca(at)skyguynca.com)
www.skyguynca.com
lrm(at)skyhawg.com Guest
Posted: Wed Jan 09, 2008 8:56 am Post subject: 701 Wings Wanted |
If you build both parts then it doesn't matter which you build first. If you follow the plans they will fit regardless of the cart or the horse. In your case John could be right, it might not be a bad idea to do a lot of measuring and build a template because someone else built the fuselage. There is no telling what you will find. However, I will say that if you buy ready made wings that don't exactly fit, you can always use shims and longer bolts. Everything is fixable.
LRM www.skyhawg.com
