bmeyette(at)gmail.com Guest
Posted: Wed Jan 09, 2008 12:13 pm Post subject: update on hangar lighting |
My electrician had suggested I'd get the most light for the cost by using an
outside yard light for my hangar shop lighting. I tried one, and it worked
great, so I documented the steps I used to do it and created a web page for
it. See here:
http://brian76.mystarband.net/HangarLights.htm
If you want inexpensive lighting, this is your best bet, from all I've seen
brian
9:14 AM
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Wed Jan 09, 2008 5:33 pm Post subject: update on hangar lighting |
Brien,
Thanks for the info on the hangar lighting.
Would it work to mount the area light, using the vertical surface mounting
arm, on the side of the horizontal member of the wood truss in my hangar? It
appears that the globe of the light would still be below the bottom level of
the truss.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Thu Jan 10, 2008 3:16 pm Post subject: update on hangar lighting |
You can also avoid all the internal wiring mods by either cannibalizing
the plug in photocell or buying a twist lock plug & hotwiring across the
switched pins. Then all you need to do is hook up black, white & ground.
One thing you might want to research is UV emission from 'yard lights'
if you plan to spend a lot of time under the lights.
You might also want to preserve your options with the diffuser.
Sometimes, removing the diffuser will get you a nice bright spot under
the light & the rest of the area will still be 'dark'.
Brian Meyette wrote:
Yes, it would work.
And you'd save all that modification work
My trusses aren't open, so I didn't have that option.
brian
d-burton(at)comcast.net Guest
Posted: Thu Jan 10, 2008 3:41 pm Post subject: update on hangar lighting |
And it's good to realize that what only looks like a diffuser can also be an
explosion proof housing to contain the screaming hot quartz pieces that are
ejected when the bulb dynamites...
Thanks for taking time to documenting this for us.
DaveB
RV6
