B747crew
Posted: Tue Jan 15, 2008 4:37 am Post subject: Engine Oil Question |
As I'm new to my Yak52 I have a question of the group>>>>
The M14P operations manual calls for oil dilution with gas for extreme cold weather operations. I also understand that winter preheating is a requirement of the oil tank, sump and oil cooler.
Has there been any consideration given to use of a lighter grade / multi grade oil in cold weather or is there any modification for bypassing the oil cooler with a thermostat until the oil reaches operating temperature?
_________________ Jack Snodgrass
4305 Claridge Ct.
Apex, NC 27539
919-745-7434 |
Posted: Tue Jan 15, 2008 5:24 am Post subject: Engine Oil Question |
Do not dilute the oil with fuel. Use Philips 25W-60 multiviscosity aviation
oil. It was designed for radial engines. The oil cooler already has a
bypass valve in it. It is always a good idea in colder climates to preheat
the oil tank, sump AND the oil cooler before starting. Even if you preheat
the oil tank and sump, you don't want to take the chance the oil in the
hoses to and from the oil cooler plus the oil in the cooler itself can
damage the oil cooler. Just use common sense when preheating.
Dennis
coolade(at)cox.net Guest
Posted: Tue Jan 15, 2008 7:12 am Post subject: Engine Oil Question |
We use Phillips 25W60 av oil,---Works great, and less concern with cold
starts.
Jack Snodgrass
4305 Claridge Ct.
Apex, NC 27539
919-745-7434
http://forums.matronics.com/viewtopic.php?p=158256#158256
B747crew
Posted: Tue Jan 15, 2008 10:54 am Post subject: Engine Oil Question |
Thanks Dennis  Jack
4305 Claridge Ct.
Apex, NC 27539
919-745-7434 |
bhancock(at)worldwidewarb Guest
Posted: Wed Jan 16, 2008 8:04 am Post subject: Engine Oil Question |
Jack,
We use the EZ Heat Engine heater to pre-heat oil in the tank. Works VERY well.
Barry
Barry Hancock Worldwide Warbirds, Inc.
office (714) 730-3958
cell (949) 300-5510
www.worldwidewarbirds.com
The information contained in this e-mail message is intended only for the personal and confidential use of the designated recipients. If the reader of this message is not an intended recipient, you are hereby notified that any review, use, dissemination, forwarding or copying of this message is strictly prohibited. Please notify us immediately by reply e-mail or telephone, and delete the original message and all attachments from your system. Thank you
