Posted: Thu Jan 17, 2008 6:11 am Post subject: ifr props, was IFR GPS requirements |
Hi Bret-
RE: ... aircraft with "composite props" could not be
certified for IFR flights.
2 of the 3 prop driven airliners I've flown in the past had composite
props. I suspect someone has gotten something crossed up somewhere.
glen matejcek
aerobubba(at)earthlink.net
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Thu Jan 17, 2008 7:57 am Post subject: ifr props, was IFR GPS requirements |
Glen, apparently the reference is in FAR part 23.867. It says as follows:
Federal Aviation Regulation
Part 23 AIRWORTHINESS STANDARDS: NORMAL, UTILITY, ACROBATIC, AND COMMUTER CATEGORY AIRPLANES
Subpart D--Design and Construction
Electrical Bonding and Lightning Protection
Sec. 23.867
[Electrical bonding and protection against lightning and static electricity.]
(a) The airplane must be protected against catastrophic effects from lightning.
(b) For metallic components, compliance with paragraph (a) of this section may be shown by--
(1) Bonding the components properly to the airframe; or
(2) Designing the components so that a strike will not endanger the airplane.
(c) For non-metallic components, compliance with paragraph (a) of this section may be shown by--
(1) Designing the components to minimize the effect of a strike; or
(2) Incorporating acceptable means of diverting the resulting electrical current so as not to endanger the airplane.
Far part 23.1 states the following:
Subpart A--General
Sec. 23.1
Applicability.
[(a) This Part prescribes airworthiness standards for the issue of type certificates, and changes to those certificates, for airplanes in the normal, utility, acrobatic and commuter categories.]
(b) Each person who applies under Part 21 for such a certificate or change must show compliance with the applicable requirements of this Part.
Soo...I would not think this applied to experimentals with the special airworthiness category.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
-----Original Message-----
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of glen matejcek
Sent: Thursday, January 17, 2008 9:09 AM
To: RV-List Digest Server
Subject: RE: ifr props, was IFR GPS requirements
--> RV-List message posted by: "glen matejcek" <aerobubba(at)earthlink.net>
Hi Bret-
RE: ... aircraft with "composite props" could not be certified for IFR flights.
2 of the 3 prop driven airliners I've flown in the past had composite props. I suspect someone has gotten something crossed up somewhere.
glen Navigator to Archive much much href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.nbsp; the Web href="http://forums.matronics.com">http://forums.matronics.com
_-========================nbsp; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
_________________ Bret Smith
RV-9A (Emp) |
